Hello All!
I received a Nardi Personal wheel for Christmas this year and decided to install it in my car. I searched for a while to find an easy way to wire the horn with no luck.. at all. Once I figured out how easy it was I figured I would post a simple thread on how to manage this.
**Note, I'm not responsible for you fucking something up. Also I used an NRG Short hub and NRG quick release for this on my 2011 GTI
Step 1: Install the Short hub onto the car while fitting the plastic piece behind it (The hub has two holes and a slot for the plastic connector to sink in.. I had to press down on the connector with my finger while installing)
Step 2: Tighten the Short hub using a T55 socket
Step 3: Wire up your horn button in the NRG quick release (This is straight forward, the red goes to red and black goes to black)
Step 4: The Short hub has a black ground wire already on it, remove that as you will not need it. Get the proper Male and Female connector and two extra pieces of wire (cut to length needed) see here:
Step 5: You'll need to get creative here but the bottom two left pins in the plastic connector are the two activate the horn once connected. I pulled two of the wires from the factory steering wheel so I could retain the metal pins, then used electrical tape to separate then tie them together. You could solder these on as well, however I wanted a simple plug and play setup
Now you're done, plug the wires together and install the wheel and you now have a working horn without having to tap any wires behind the steering wheel.
