Darryl@HPA
Gen.4 0BR Competition Haldex Controller
Unlike other aftermarket Haldex controllers, HPA’s Competition unit retains rear driveline engagement under braking; a key advantage in motorsports, and for driving enthusiasts.
The HPA Gen.4 Competition Controller is calibrated similar to the "Race mode" setting used in the standard Gen.4 Performance Controllers, but has the additional feature of increasing the clutch torque when braking. By doing so, wheel brake torque is now transferred rearwards through the AWD clutch, offering a far more aggressive deceleration capability. Additionally, the Competition controller will support left foot braking without disengaging the 4-motion clutch while out on the track.
This Gen.4 Competition unit does not offer the selectable modes offered in our standard Gen.4 Haldex Performance Controllers (Stock, Race, and Eco, for reference), and therefore no extra switch or remote is required.
3-mode (Race / Eco / Stock) “Switchable” Haldex controllers are also available. Golf R –specific bundles featuring an additional wireless remote/receiver or cable/switch can be ordered in lieu of our Competition variant if desired.
More information on HPA's exclusive Competition Haldex Controllers can be found here.
Core Interlock Dog Bone Mount
Our upgraded mounts reduce motor flex to improve torque transfer to the drivetrain, and prevent excessive movement under hard acceleration. Shifter engagement is faster and easier and stability is improved. These mounts will solidify the engine's connection to the chassis while still isolating its vibrations from the cabin.
The unique Core Interlock design was born to balance sensitive chassis harmonics while maintaining a comfortable feel of the engine at idle.
Unlike other urethane inserts which merely reinforce the OEM rubber mount; this is a completely re-engineered one stop solution that will control the engine’s motion without the need to install aftermarket side mounts.
The 75a (Red) mount is considered to be the best match for the Golf R, providing optimized performance without excessive cabin vibration. Stiffer (race inspired) durometer mounts are also available upon request.
Additional details on HPA's Dog Bone Mounts can be found here.
02M Short Throw Shifter
The HPA Short Throw Shifter is manufactured from a dedicated casting which is CNC machined to precise tolerances.
For the Golf R platform, these versatile pieces of hardware can be set up on one of two different positions to suit your preference: a sporty 20% reduction in throw or a more aggressive 35%/40% reduction.
The perfectly balanced shifter counter weight gives each shift a precise and positive engagement and greatly improves the feeling over the sloppy stock shifter.
The bright zinc plated finish ensures that the stock appearance of your engine compartment is maintained while protecting the casting from corrosion. Includes threaded pin / ball connection for connecting the shifter linkage.
More information on HPA's Short Throw Shifters can be found here.
High Performance Brake Kits
HPA is pleased to offer its High Performance Brake Kits for Mk5/Mk6 VW and Audi TT/A3 applications. The HPA Brake Kits are designed in conjunction with BAER Brakes and proudly made in the USA.
Key Design Elements:
Wheel Fitment: Unlike most Big Brake Kits, the HPA system is designed to fit behind the OEM 18" GTI, GLI, or Golf R wheels without any spacers. Note: Factory dust shield must be removed to accommodate larger rotor.
Weight Savings: These kits shave 6 pounds of rotational mass per rotor, which results in improved acceleration and deceleration, and a total of 32 pounds of un-sprung weight for improved suspension function.
Calipers: CNC machined from billet aluminum, the fixed calipers are designed to increase rigidity, improve braking efficiency, and improve pedal feel. Featuring internal crossover pipes, these calipers have a sleek streamlined look with no fragile external components. Pistons are sized to HPA specification with exact piston bore for perfect front and rear balance. Piston seals protect from dust, weather, and pressure to meet DOT spec.
Rotors: Two piece floating rotor with directional curved vanes, and HPA curved slots. Hats are anodized CNC machined aluminum, and discs are zinc-plated for corrosion protection.
Pads: The ceramic compound pads included with the kit are suitable for street and mild track use. They create minimal brake dust and are relatively quiet. Sharing the same profile as Corvette C5/C6, there are many different replacement options available on the open market. Note: the OEM pad wear sensors are eliminated.
Features:
Clears OEM 18" Wheels with NO Spacer Required
Un-sprung Weight Savings of 16 lbs. Per Side, 6 lbs. on the Rotational Weight of Each Rotor
Choice of Red, Black, Silver or HPA Blue
Readily Available Replacement Parts
One Year Warranty
Front Brake Kit
Includes:
Front 6 Piston Radial Mount Caliper
Slotted Two Piece floating Rotor 355mm x 32mm thick
Caliper Brackets
Ceramic Pads
Mounting Hardware
DOT approved Direct Fit Stainless Steel Braided Brake Lines
Brake Bleeding Accessory
Rear Brake Kit
Includes:
Rear 4 Piston radial mount caliper
Slotted two-piece floating rotor 335mm
Caliper brackets
Ceramic pads
Integrated backing plate w/custom drum e-brake
Custom cables
DOT-approved direct fit stainless steel braided brake lines
Mounting hardware
Package pricing is available on the purchase of a front/rear brake kit combination. Contact HPA for details.
Additional information on HPA's High Performance Brake Kits can be found here.
SHS Coilovers
Developed in conjunction with the engineers at KW Automotive, the team at HPA Motorsports provides an out of the box coilover solution that is preset to perform.
HPA’s SHS coilovers offer an unmatched balance between handling and comfort. All SHS applications are based off KW’s twin tube low pressure damper design. Embracing KW’s patented valve technology, the high-speed dampening characteristics remain similar to OEM offering a near factory comfort level, while the low speed dampening power is increased to eliminate pitch and roll associated with heavy braking or corner entry. Each application features linear race springs on the front and progressive barrel springs on the rear.
SHS is an ideal suspension solution for the Golf R enthusiast looking to gain better control at corner entry on high-speed sprints, yet uses their car as a daily driver in the harsh real world environment.
Key Features:
Lowering Range:
Part # HPA-204 - Mk6 R SHS Coilovers
Front 25-55mm
Rear 35-60mm
Price quotes for drop shipping to your location are available upon request. Kits are built on a per order basis in KW Germany, and then drop shipped direct to our customers.
Additional information on HPA's SHS Coilovers can be found here.
If you have additional questions regarding these or any other HPA products, feel free to IM or e-mail us directly.
To order any of our Golf R performance products contact HPA Motorsports at 604.888.7274 and place your order. Package pricing will be offered for 2 or more items purchased at one time. Visa and MasterCard are accepted, and PayPal can be set up upon request.
Features:
One Year Warranty
Front Brake Kit
Includes:
Caliper Brackets
Ceramic Pads
Mounting Hardware
Rear Brake Kit
Includes:
Caliper brackets
Ceramic pads
Custom cables
Mounting hardware
SHS Coilovers
Key Features:
- Stainless steel construction guarantees the height adjustability won’t be lost through commuting on salt covered winter roads (KW INOX technology).
- Self- centering integrated dust boots, which keep the winter sand and debris from damaging the piston rod seal for long life.
- Stainless steel impregnated composite spring seats offer easy ride height adjustment all season long. No binding conventionally found with aluminum seats.
- Race Springs are EPS powder and zinc-phosphate coated for long life.
- Springs are made from chrome-silicon steel 54SiCR6 offering higher carry capacity with less material than standard steel wound springs.
- Height adjustable on all 4 corners
- Spanner Wrenches included for adjusting ride height
Lowering Range:
Front 25-55mm
Rear 35-60mm
