Darryl@HPA
DSG / S-tronic Performance Programming
HPA’s renowned DSG performance software[/B][/URL] is available for all VW/Audi DQ250 DSG gearboxes, including the Audi A3/A3 TDI, Audi TT-S, Mk5/6 Golf/GTI/Jetta/GLI, and VW Passat/CC.
DQ200 (7-speed), DQ500 (TT-RS, Transporter, etc.), and DL501 (B8 Audi Chassis) are on schedule for release in the near future…
DSG Stages
DSG performance involves a synergetic relationship between shift call outs, engine load, driver demand, and mechanical execution. Within these relationships, a harmonic balance must be maintained to ensure the various integrated systems work together and do not overpower their basic limitations.
In addition, with the TDI gaining in popularity, HPA has assembled a TDI-Specific DSG upgrade suited to the power characteristics of this fuel efficient power plant. The DSG is a brilliant piece of technology, and HPA has now perfected its union with the TDI engine.
HPA's Stage 2 / Stage 2 TDI DSG Program includes following features:
Progressive Shift Response
Torque Limit Increase
Launch Control
Increased Red Line
Eliminated Automatic Shifting
In-Dash Gear Display
Detailed information on these features, and our TDI-specific benefits can be found here.
Stage 3 software is a must for all 400+ HP applications and those drivers who demand the most out of their chassis in D, S, or M mode. In addition to the upgrades offered in the Stage 2 package, Stage 3 includes the following benefits listed here.
For DSG equipped cars with modified Forced Induction applications, or those boasting 450+HP, the Stage 4 offering is a necessity. It offers all of the benefits of Stage 3, but is fully customized to suit your vehicle needs. Details here. .
All HPA DSG offerings are available in house at HPA, through our worldwide dealer network, and through our loaner tool program.
For those interested in HPA ECU Software as well, special combo pricing is available upon request. Please contact HPA for details.
Additional details on HPA's DSG / S-tronic Performance Programming can be found here.
Core Interlock Dog Bone Mount
Our upgraded mounts reduce motor flex to improve torque transfer to the drivetrain, and prevent excessive movement under hard acceleration. Shifter engagement is faster and easier and stability is improved. These mounts will solidify the engine's connection to the chassis while still isolating its vibrations from the cabin.
The unique Core Interlock design was born to balance sensitive chassis harmonics while maintaining a comfortable feel of the engine at idle.
Unlike other urethane inserts which merely reinforce the OEM rubber mount; this is a completely re-engineered one stop solution that will control the engine’s motion without the need to install aftermarket side mounts.
The 75a (Red) mount is considered to be the best match for the Mk6 Chassis, providing optimized performance without excessive cabin vibration. Stiffer (race inspired) durometer mounts are also available upon request.
Additional details on HPA's Dog Bone Mounts can be found here.
02M Short Throw Shifter
The HPA Short Throw Shifter is manufactured from a dedicated casting which is CNC machined to precise tolerances.
For the Mk6 platform, these versatile pieces of hardware can be set up on one of two different positions to suit your preference: a sporty 20% reduction in throw or a more aggressive 35%/40% reduction.
The perfectly balanced shifter counter weight gives each shift a precise and positive engagement and greatly improves the feeling over the sloppy stock shifter.
The bright zinc plated finish ensures that the stock appearance of your engine compartment is maintained while protecting the casting from corrosion. Includes threaded pin / ball connection for connecting the shifter linkage.
More information on HPA's Short Throw Shifters can be found here.
High Performance Brake Kits
HPA is pleased to offer its High Performance Brake Kits for Mk4/Mk5/Mk6 VW and Audi TT/A3 applications. The HPA Brake Kits are designed in conjunction with BAER Brakes and proudly made in the USA.
Key Design Elements:
Wheel Fitment: Unlike most Big Brake Kits, the HPA system is designed to fit behind the OEM 18" wheels without any spacers. Note: Factory dust shield must be removed to accommodate larger rotor.
Weight Savings: These kits shave 6 pounds of rotational mass per rotor, which results in improved acceleration and deceleration, and a total of 32 pounds of un-sprung weight for improved suspension function.
Calipers: CNC machined from billet aluminum, the fixed calipers are designed to increase rigidity, improve braking efficiency, and improve pedal feel. Featuring internal crossover pipes, these calipers have a sleek streamlined look with no fragile external components. Pistons are sized to HPA specification with exact piston bore for perfect front and rear balance. Piston seals protect from dust, weather, and pressure to meet DOT spec.
Rotors: Two piece floating rotor with directional curved vanes, and HPA curved slots. Hats are anodized CNC machined aluminum, and discs are zinc-plated for corrosion protection.
Pads: The ceramic compound pads included with the kit are suitable for street and mild track use. They create minimal brake dust and are relatively quiet. Sharing the same profile as Corvette C5/C6, there are many different replacement options available on the open market. Note: the OEM pad wear sensors are eliminated.
Features:
Clears OEM 18" Wheels with NO Spacer Required
Un-sprung Weight Savings of 16 lbs. Per Side, 6 lbs. on the Rotational Weight of Each Rotor
Choice of Red, Black, Silver or HPA Blue
Readily Available Replacement Parts
One Year Warranty
Front Brake Kit
Includes:
Front 6 Piston Radial Mount Caliper
Slotted Two Piece floating Rotor 355mm x 32mm thick
Caliper Brackets
Ceramic Pads
Mounting Hardware
DOT approved Direct Fit Stainless Steel Braided Brake Lines
Brake Bleeding Accessory
Rear Brake Kit
Includes:
Rear 4 Piston radial mount caliper
Slotted two-piece floating rotor 335mm
Caliper brackets
Ceramic pads
Integrated backing plate w/custom drum e-brake
Custom cables
DOT-approved direct fit stainless steel braided brake lines
Mounting hardware
Package pricing is available on the purchase of a front/rear brake kit combination. Contact HPA for details.
Additional information on HPA's High Performance Brake Kits can be found here.
SHS Coilovers
Developed in conjunction with the engineers at KW Automotive, the team at HPA Motorsports provides an out of the box coilover solution that is preset to perform.
HPA’s SHS coilovers offer an unmatched balance between handling and comfort. All SHS applications are based off KW’s twin tube low pressure damper design. Embracing KW’s patented valve technology, the high-speed dampening characteristics remain similar to OEM offering a near factory comfort level, while the low speed dampening power is increased to eliminate pitch and roll associated with heavy braking or corner entry. Each application features linear race springs on the front and progressive barrel springs on the rear.
SHS is an ideal suspension solution for the enthusiast looking to gain better control at corner entry on high-speed sprints, yet uses their car as a daily driver in the harsh real world environment.
Key Features:
Lowering Range:
Part # HPA-205 - Mk6 SHS Coilovers
Front 35-65mm
Rear 35-65mm
Price quotes for drop shipping to your location are available upon request. Kits are built on a per order basis in KW Germany, and then drop shipped direct to our customers.
Additional information on HPA's SHS Coilovers can be found here.
If you have additional questions regarding these or any other HPA products, feel free to IM[/B] or e-mail us directlysales@hpamotorsport.com.
To order any of our performance products contact HPA Motorsports at 604.888.7274 and place your order. Package pricing will be offered for 2 or more items purchased at one time. Visa and MasterCard are accepted, and PayPal can be set up upon request.
DSG Stages
Launch Control
Increased Red Line
Features:
One Year Warranty
Front Brake Kit
Includes:
Caliper Brackets
Ceramic Pads
Mounting Hardware
Rear Brake Kit
Includes:
Caliper brackets
Ceramic pads
Custom cables
Mounting hardware
SHS Coilovers
Key Features:
- Stainless steel construction guarantees the height adjustability won’t be lost through commuting on salt covered winter roads (KW INOX technology).
- Self- centering integrated dust boots, which keep the winter sand and debris from damaging the piston rod seal for long life.
- Stainless steel impregnated composite spring seats offer easy ride height adjustment all season long. No binding conventionally found with aluminum seats.
- Race Springs are EPS powder and zinc-phosphate coated for long life.
- Springs are made from chrome-silicon steel 54SiCR6 offering higher carry capacity with less material than standard steel wound springs.
- Height adjustable on all 4 corners
- Spanner Wrenches included for adjusting ride height
Lowering Range:
Front 35-65mm
Rear 35-65mm
