If you want ultimate set it and forget it longevity, get Bilstein dampers and DG springs.
Bilsteins will retain 97%+ damping coefficient even after 100k miles.
Some will counter this with "well x brand has a warranty blah blah". To that I say... I'll let this guy tell you about warranties.
http://youtu.be/mEB7WbTTlu4?t=59s
Hi Ryan! :word:
What do you think about Golf R shocks and DG Springs?
May be different bc of the AWD system? Not sure tho. But keep that in mind.
Thoughts on how the ST's compare to the HPA SHS's?
Doubt that affects anything. Just weight is the only factor I would guess. Might not be a bad idea.
Sounds like it will be much more stiffer!
Welcome back Matt! :clap:
Anything this man says is gospel, he is the foremost suspension master.
Right here, northern NJ roads are pretty brutal and I sit at 25" FTG all around.
These coilovers are great street/track coilovers [halfway down], but if you plan to go all the way down, get Koni.
Anyone with the ST's experiencing an uneven ride height from side to side (especially in the rear)? I have about 1/4" of threads showing in the back (set collars perfectly by laying them side by side and matching) yet have a decent ftg level from drivers side to passenger side. Drivers side is lower. I'm all the way down in the front and running about 24.5 ftg pretty even side to side. Not sure what's up with the rear though. Could it be a slight variation in the springs?
