RacingManiac
The greasing for me isn't an issue at all, the number of times I swapped pads between track and street pads last summer means that they get re-greased each time I swap them....
Thanks Paul, you were the first one in Tyrol Sport so thank you for passing them along!
FYI I'm looking forward to a Deadset Rear upgrade as well. I doubt it'll be AS needed, but certainly it would help!
Any ETA from them?
It's a $2 bolt to begin with:
http://www.ecstuning.com/Volkswagen-Golf_V--2.0T/Suspension/Subframe/ES8640/
The non-tapered can cause some of the threads to engage but possibly cross thread. OR not engage at all. The entire joint has three parts to center: Console, Subframe, and Whitebody (Vehicle Frame). To center all of them takes quite the effort and if your threads cannot engage, then you cannot "force" the two lower joints (Did not show the console in the picture) to align with the body. It took me about 15mins of struggling, before I finally gave up and used the taper ended bolts.
