Here you go.
- Remove
front door trim..
- Pry out cover caps -
6 -.
- Lower the door window -
2 - until the screws -
3 - are accessible.
- Loosen the screws -
3 - (left-hand thread) but do not remove and press the clamping brackets apart.
- Lift the door window -
1 - and secure it, for example, with adhesive tape.
♦ On one series of vehicles, up to 3 clips have been replaced by rivets.
♦ These rivets are being replaced by clips again at installation.
- Open the catches -
arrow a - and pull off the protective sleeve -
3 -.
- Open the locking mechanism on the connector by pivoting it downward -
arrow b - and disconnect the connector.
- Disconnect the connectors on the door lock and the speaker -
5 -.
- Remove the caps -
6 - and remove the screws -
7 -.
- Remove the clips -
arrows - with pliers -
8 - -
arrow c -.
- Disconnect the connector on the window regulator motor for the exterior mirror -
7 -.
- Remove the wiring harness for the exterior mirror -
4 -.
- Move the subframe -
1 - upward just a little -
arrow a -.
- Remove the subframe -
1 - and the window regulator -
5 - at an angle -
arrows b - from the door.
- Remove the wiring harness -
2 - from the mount -
3 -.
- When pulling out subframe -
1 -, guide out wiring harness -
2 - accordingly.
Installation
- Insert subframe upward -
arrow a - at an angle into door.
- Pull the connector -
3 - through the door and secure the wire holder -
2 -.
- Pull the cable -
7 - through the subframe. Make sure the grommet fits correctly.
- Push the subframe -
1 - at the lower area on the door -
arrow b -.
- Route the wires -
4 - on the subframe.
- Connect the electrical connectors -
5 and 8 -.
♦ Press the subframe firmly against the door when installing the clips.
♦ Gently push in the pins on the clips so that the subframe seal fits correctly.
♦ It will be difficult to install the clips with the subframe is not pressed firmly against the door.
♦ The clips will get caught and the seal will not fit properly. This means the door will not be sealed.
- Press the subframe firmly -
1 - against the door.
- Mount the clips -
arrows - and press the pins in.
- Tighten the bolts -
7 -.
- Install the door window. Refer to => [
Front Door Window ] .
3 and 5 -.
- Continue by performing the steps used in removal in reverse order.
♦ A function test must be performed before door trim is installed.
Tightening Specifications
