Just maps or the whole system?Mine switch automatic maps to dark mode at night.... there is a switch, but I dont remember where it was
Maps only. I am always using dark theme.Just maps or the whole system?
serious? how can mine always stay on day mode. It doesn't switch between day and night for meMine switch automatic maps to dark mode at night.... there is a switch, but I dont remember where it was
Open up the VW satnav and view the map. At the bottom of the map screen is a button with 3 horizontal lines. Press it, you will be presented with a screen with 3 options Auto, Day and Night. Choose Auto.serious? how can mine always stay on day mode. It doesn't switch between day and night for me
i meant my android car! the navigation of the car itself works well, only android auto does not switch from day and night modeOpen up the VW satnav and view the map. At the bottom of the map screen is a button with 3 horizontal lines. Press it, you will be presented with a screen with 3 options Auto, Day and Night. Choose Auto.
Your VW satnav will change from day to night automatically.
This is different from the rest of the screen, it's only the VW satnav.
The rest of the screen must be selected day or night manually, there isn't an auto option.
I have my system set to Dark (using the pull down menu, but I have the VW satnav set to automatic.
Go into Google Maps on the phone.i meant my android car! the navigation of the car itself works well, only android auto does not switch from day and night mode
I can only go off what's been said. The posts have been about the VW satnav, no mention of Android auto until I give the answer for the VW satnav .i meant my android car! the navigation of the car itself works well, only android auto does not switch from day and night mode
That's because AA uses the cars system theme. If it's in dark mode AA will also be like that. Most cars use the light sensor to change between night/day mode, but for VW it's either dark or light.I can only go off what's been said. The posts have been about the VW satnav, no mention of Android auto until I give the answer for the VW satnav .
Android Auto doesn't change automatically, even though it should, I've tried every combination, including the one posted by CH47AV8R.
As I've said previously I set my VW to dark so that Android Auto is dark.
Yes. So Android Auto doesn't change automatically, even though AA says it should.That's because AA uses the cars system theme. If it's in dark mode AA will also be like that. Most cars use the light sensor to change between night/day mode, but for VW it's either dark or light.
In the '22 NAR R with Android Auto/Google Maps, Google maps certainly change to dark mode at the local sunset time for me.I can only go off what's been said. The posts have been about the VW satnav, no mention of Android auto until I give the answer for the VW satnav .
Thanks, I'll give it a try.In the '22 NAR R with Android Auto/Google Maps, Google maps certainly change to dark mode at the local sunset time for me.
Phone - Settings/Display/Dark Mode Settings/Sunset to sunrise
Google Maps (in phone) - Theme/Same as device theme; Navigation Settings/Map Display/Color Scheme-Automatic
Android Auto (in phone) - General-Day/Night Mode for maps/Automatic
Just tried it as you suggested. All settings exactly as you described.In the '22 NAR R with Android Auto/Google Maps, Google maps certainly change to dark mode at the local sunset time for me.
