Items covered under PZEV Warranty
dub*man
Hi all - I thought it would be a good idea to put together a list of items covered under PZEV warranty.
I was recently told that the timing cover oil leak is covered which was a surprise to myself.
Let us compile a list and I will update the OP.
Service Number/ Component
1714 Oil Filler Cap
1726 PCV Valve
1911 Coolant Level Sensor
1913 Coolant Fan Con. Switch
1970 Direct Ozone Reduction (DOR) Radiator/Sensor
1978 Temperature Sending Unit
2005 Fuel Filler Cap
2007 Filler Neck
2010 Fuel Tank
2019 Gravity Valve
2022 Activated Charcoal Line
2024 Canister Purge Solenoid/Valve
2025 Canister
2038 Fuel Feed Line
2039 Fuel Return Line
2044 Fuel Line
2048 Leak Detection Pump
2057 Pressure Relief Valve
2058 Fuel Accumulator
2065 Fuel Pump Relay
2130 Turbo Charger
2143 Charge Inter-Cooler
2164 Over Run Cut-off Valve
2168 Pressure Sender
2169 Solenoid Shut-off Valve
2329 Diesel Injection Pump
2340 1 Injector with Lift Sensor
2359 Diesel Air Mass Meter
2360 Diesel ECM
2425 Air Cleaner Housing
2426 Intake Air Temp. Sensor
2433 Switching Valve
2438 Heated Air Duct
2440 Injectors
2441 Fuel Distributor
2442 Throttle Body
2444 Throttle Position
2445 Air Flow Sensor
2447 Intake Manifold
2458 Fuel Pressure Regulator
2460 Cold Start Valve/Injector
2461 Throttle Position Sensor
2462 Engine Coolant Temp. Sensor
2468 Oxygen Sensor Relay
2469 Pre-Oxygen Sensor
2470 Electronic Control Module
2473 Post Oxygen Sensor
2481 Idle Air Control Valve
2510 Heated Oxygen Sensor
2511 Engine Control Module
2513 Differential Pressure Reg.
2514 VAF Sensor Position Sensor
2519 Engine Coolant Temperature Sensor
2525 Air Cleaner Housing
2527 Intake Air Duct
2540 Fuel Injectors
2544 Throttle Body
2548 Cold Start Valve/Injector
2555 Fuel Pressure Regulator
2560 Fuel Distributor
2562 Volume Air Flow Sensor
2567 Vacuum Amplifier
2568 Idle Air Control Valve
2574 Throttle Position Switch/Sensor
2580 Intake Manifold
2588 Idle Air Control Valve System
2604 CO Content Pipe
2610 Exhaust Manifold
2617 Exhaust Pipe (Manifold to Catalyst)
2639 EGR Valve
2640 Secondary Air Injection Shut-Off Check Valve
2641 EGR Vacuum Hoses
2642 EGR Temperature Sensor
2644 Solenoid Valve
2654 Thermal Vacuum Valve
2655 Secondary Air Injection Relay
2665 Secondary Air Injection Pump
2668 Anti-Backfire Valve
2670 Pre-catalytic Converter
2672 Three-Way Catalytic Converter Temperature Sensor
2673 Three-Way Catalytic Converter
2817 Ignition Coil Power Output Stage
2820 Ignition Coil (Tri-Coil Pack)
2823 Ignition System Control Module
2830 Distributor Assembly
2832 Distributor Cap
2834 Distributor Rotor
2839 Vehicle Speed Sensors (Camshaft Position Sensor)
2853 Spark Plug Wires
2855 Coil Wire
2870 Spark Plugs
2872 Knock Sensors
2873 Crankshaft Position Sensor
2884 Glow Plug
2885 Glow Plug Relay
3707 Park Neutral Switch
3730 Transmission Control Module
9009 Speed Sensor
9025 Instrument Cluster
jettaglis
Here's a master list...
PZEV/AT-PZEV California Emissions Warranties
15 Years/150,000 Miles, whichever occurs first
1714 Oil Filler Cap
1726 PCV Valve
2007 Filler Neck
2010 Fuel Tank
2019 Gravity Valve
2025 Canister
2038 Fuel Feed Line
2044 Fuel Line
2130 Turbo Charger
2360 Diesel ECM
2440 Injectors
2442 Throttle Body
2540 Fuel Injectors
2544 Throttle Body
2639 EGR Valve
2644 Solenoid Valve
2855 Coil Wire
2870 Spark Plugs
2872 Knock Sensors
2884 Glow Plug
9009 Speed Sensor
N/A MIL Lamp
dub*man
Injectors meaning if my injector was stuck open - VW should have covered that?
I was turned away from dealer at 121k (extended warranty covered until 120k)
Was I misinformed about the oil leak?
Im thinking a post on Facebook mk6 group will get some more responses as well!
sergysmooth
Was posting to see if anyone had any knowledge that could help my situation. Had a stud break on the exhaust manifold and am looking to make a claim through pzev because my car has 90k miles on it. I went to the dealership and they said they aren't sure because the part that is listed under warranty is the exhaust manifold itself and not the stud. While I am quite of aware of how petty these dealerships can be, does anyone know if the stud could possibly be considered as part of the exhaust manifold?
snobrdrdan
former GTI owner
Ask the dealer....it's their call, not ours
Btw....the stud broke on it's own, and you just happened to be looking under there & found it?
VEGASVWGTI
Where is this master list pulled from guys? Are these numbers the codes found when the item fails?
Is the fuel filler cap 2005 the gas cap? I assume so but not sure.
The dealer is claiming a defective gas cap is not covered, nor is the faulty sensor measuring coolant in the top of the radiator requiring full replacement covered either. Note: this is out of CA currently so they may be less familiar.
GTiMKVI
So if I have a 2011 GTi with 68500 miles that is showing low coolant levels, should I tip it off and bring it to the dealer without worrying that the issue will not be covered? They love to charge that $135 diagnostic, so trying to avoid that if there is a possibility that this emissions warranty wouldn’t cover it.
Thanks
Damn, I just crossed the 150,000 mark and my check engine light came on.
I went to Autozone to get the code checked and it came up as P2187 System Too Lean at Idle Bank 1 and they are saying that this is a common issue with my car and it should be linked to a failing Mass Air Flow (MAF) sensor.
Is this part of the covered list? Just finding this list so I have not completely read up on it so I am wondering if I have any chance of getting this replaced for free.
jettaglis
It's probably a bad pcv valve. If your over miles your sol.
From what I've read aftermarket PCV valves don't last as long as the oem ones. I'll be replacing mine after a few more miles as a preventative meassure.
GTiMKVI
My car is a PZEV. The dealer did an APR flash when I bought it off my lease, and they have honored any warranty issues to date. Well not really, they charged me for spark plugs and coils which should have been covered under the warranty, and I’m trying to get that back. When they flashed the ecm, they did it by cracking the box open. Now the fans run after turning the car off, which is a sign of ecm failure. I took the car to the dealer and after 4 days they said it was the fans that were the issue. I told them that I had it deviously checked and it wasn’t the fans, but they changed them anyway and figured out that it was the ecm. Now they want t charge me from r the fans they replaced, saying that supposedly they were bad, and won’t cover the ecm because it was cracked open and if sent back to VW it would void the warranty. Forget the fact that last week they told me that the fans would cost $720, and today they said they made a mistake and they are actually $1,100. I was like “why wouldn’t you call me to let me know of the mistake before doing the job?” I asked them for a credit for the $550 I spent for the coils even though they should have been covered, and also told them that I would only pay $720 b cause that’s what I was quoted, even though I shouldn’t pay anything as the fans were never the issue, just a misdiagnosis by them. They will get back to me n Monday with a decision, but I doubt they do anything. I’m probably going to have to buy a used ECM that has never been flashed.
My code is 1K0907115AQ in case anyone can help. And if I get one, do the miles matter? I’ve seen one come off a car that had 134k miles. My car has 69k.
Thanks for your help
