Is.youssef
H there need your help, please
Some info here. I'm in a 2013 MK6R K04, Forge intake and 3 inch downpipe.I'm running Unitronic Stage 2+ tune (93 octane). have an issue that boost kicks in and then it just seems to die off. My boost gauge shows that boost touches 20-21psi and then just constantly drops until it's dropped to about 12psi. From looking at the logs, it appears that's not the case, but I'm wondering why I see that on the boost gauge. N75 seems to drop off early (or be all over the place). And on two of my runs, my throttle valve angle went to about 50% after boost kicked in even though the accel pedal was pegged the whole time.
any thoughts? my car is running like crap
TIME | Group 2 - Field 0 | TIME | Group 2 - Field 3 | TIME | Group 6 - Field 2 | TIME | Group 20 - Field 0 | TIME | Group 20 - Field 1 | TIME | Group 20 - Field 2 | TIME | Group 20 - Field 3 | TIME | Group 31 - Field 0 | TIME | Group 61 - Field 2 | TIME | Group 114 - Field 3 | TIME | Group 115 - Field 2 | TIME | Group 118 - Field 3 |
STAMP | Engine Speed - (G28) | STAMP | Mass Air Flow - Sensor (G70) | STAMP | Intake Air - Temperature (G42) | STAMP | Timing Retardation - Cylinder 1 | STAMP | Timing Retardation - Cylinder 2 | STAMP | Timing Retardation - Cylinder 3 | STAMP | Timing Retardation - Cylinder 4 | STAMP | Lambda Control - Bank 1 (actual) | STAMP | Throttle Valve Angle | STAMP | Boost Pressure - Control (N75) | STAMP | Boost Pressure - (specified) | STAMP | Boost Pressure - (actual) |
/min | g/s | °C | °KW | °KW | °KW | °KW | % | % | mbar | mbar | |||||||||||||
0.04 | 3960 | 0.04 | 44.61 | 0.09 | 43 | 0.14 | 0 | 0.14 | 0 | 0.14 | 0 | 0.14 | 0 | 0.19 | 0.95 | 0.24 | 25.9 | 0.27 | 0.8 | 0.32 | 1110 | 0 | 1360 |
0.43 | 4040 | 0.43 | 75.69 | 0.48 | 43 | 0.53 | 0 | 0.53 | 0 | 0.53 | 0 | 0.53 | 0 | 0.57 | 1.03 | 0.62 | 45.9 | 0.67 | 49.4 | 0.71 | 2410 | 0.38 | 1560 |
0.82 | 4200 | 0.82 | 139.03 | 0.87 | 44 | 0.91 | 0 | 0.91 | 0 | 0.91 | -4.5 | 0.91 | 0 | 0.96 | 0.97 | 1.02 | 40.4 | 1.06 | 56.9 | 1.11 | 2400 | 0.77 | 1950 |
1.2 | 4440 | 1.2 | 155.42 | 1.26 | 44 | 1.31 | -1.5 | 1.31 | 0 | 1.31 | -3.8 | 1.31 | -1.5 | 1.36 | 0.88 | 1.41 | 43.9 | 1.46 | 50.6 | 1.51 | 2400 | 1.15 | 2620 |
1.6 | 4680 | 1.6 | 156.03 | 1.66 | 43 | 1.7 | -1.5 | 1.7 | 0 | 1.7 | -3.8 | 1.7 | -1.5 | 1.74 | 0.86 | 1.8 | 47.5 | 1.84 | 48.6 | 1.88 | 2410 | 1.55 | 2640 |
1.98 | 4960 | 1.98 | 158.28 | 2.02 | 42 | 2.08 | -0.8 | 2.08 | 0 | 2.08 | -3 | 2.08 | -0.8 | 2.12 | 0.88 | 2.17 | 49 | 2.21 | 50.6 | 2.27 | 2430 | 1.93 | 2460 |
2.37 | 5200 | 2.37 | 169.22 | 2.43 | 42 | 2.48 | -0.8 | 2.48 | 0 | 2.48 | -3 | 2.48 | -0.8 | 2.53 | 0.85 | 2.58 | 49.8 | 2.62 | 52.5 | 2.67 | 2450 | 2.33 | 2450 |
2.76 | 5440 | 2.76 | 180.53 | 2.8 | 42 | 2.86 | 0 | 2.86 | 0 | 2.86 | -3 | 2.86 | 0 | 2.9 | 0.84 | 2.94 | 50.6 | 2.99 | 53.7 | 3.04 | 2440 | 2.72 | 2490 |
3.13 | 5680 | 3.13 | 188.75 | 3.18 | 42 | 3.23 | 0 | 3.23 | 0 | 3.23 | -2.3 | 3.23 | 0 | 3.28 | 0.82 | 3.34 | 51.8 | 3.39 | 55.7 | 3.45 | 2400 | 3.09 | 2490 |
3.54 | 5960 | 3.54 | 195.67 | 3.59 | 41 | 3.64 | 0 | 3.64 | 0 | 3.64 | -2.3 | 3.64 | 0 | 3.68 | 0.81 | 3.72 | 52.2 | 3.77 | 55.7 | 3.82 | 2370 | 3.49 | 2470 |
3.91 | 6160 | 3.91 | 205.33 | 3.96 | 41 | 4.01 | 0 | 4.01 | 0 | 4.01 | -1.5 | 4.01 | 0 | 4.06 | 0.8 | 4.11 | 61.2 | 4.15 | 54.9 | 4.19 | 2330 | 3.87 | 2480 |
4.29 | 6400 | 4.29 | 214.89 | 4.35 | 41 | 4.4 | 0 | 4.4 | 0 | 4.4 | -1.5 | 4.4 | 0 | 4.44 | 0.8 | 4.49 | 85.5 | 4.54 | 56.5 | 4.59 | 2280 | 4.24 | 2370 |
4.69 | 6600 | 4.69 | 215.67 | 4.74 | 42 | 4.79 | 0 | 4.79 | 0 | 4.79 | -1.5 | 4.79 | 0 | 4.84 | 0.8 | 4.88 | 85.9 | 4.93 | 57.6 | 4.98 | 2250 | 4.64 | 2330 |
5.07 | 6760 | 5.07 | 219.69 | 5.11 | 42 | 5.17 | 0 | 5.17 | 0 | 5.17 | -0.8 | 5.17 | 0 | 5.21 | 1.99 | 5.25 | 85.9 | 5.3 | 72.2 | 5.34 | 2460 | 5.02 | 2290 |
5.45 | 5160 | 5.45 | 200.53 | 5.5 | 42 | 5.55 | 0 | 5.55 | 0 | 5.55 | -2.3 | 5.55 | -1.5 | 5.59 | 0.86 | 5.64 | 80.4 | 5.7 | 52.5 | 5.74 | 2440 | 5.4 | 2600 |
5.83 | 5280 | 5.83 | 191.36 | 5.88 | 42 | 5.93 | 0 | 5.93 | 0 | 5.93 | -2.3 | 5.93 | -1.5 | 5.98 | 0.79 | 6.03 | 89 | 6.08 | 52.5 | 6.13 | 2450 | 5.79 | 2600 |
6.23 | 5440 | 6.23 | 186.11 | 6.28 | 43 | 6.33 | 0 | 6.33 | 0 | 6.33 | -1.5 | 6.33 | -0.8 | 6.38 | 0.83 | 6.44 | 90.6 | 6.49 | 56.9 | 6.53 | 2460 | 6.17 | 2430 |
6.63 | 5560 | 6.63 | 200.5 | 6.68 | 43 | 6.72 | 0 | 6.72 | 0 | 6.72 | -1.5 | 6.72 | -0.8 | 6.77 | 0.81 | 6.82 | 88.2 | 6.86 | 57.6 | 6.91 | 2430 | 6.58 | 2480 |
7 | 5680 | 7 | 208.06 | 7.06 | 44 | 7.11 | 0 | 7.11 | 0 | 7.11 | -1.5 | 7.11 | -0.8 | 7.16 | 0.8 | 7.21 | 87.8 | 7.26 | 56.9 | 7.3 | 2410 | 6.96 | 2560 |
7.41 | 5840 | 7.41 | 206.14 | 7.46 | 44 | 7.51 | 0 | 7.51 | 0 | 7.51 | -0.8 | 7.51 | 0 | 7.56 | 0.8 | 7.61 | 88.2 | 7.66 | 56.9 | 7.7 | 2390 | 7.36 | 2510 |
7.8 | 5960 | 7.8 | 207.11 | 7.84 | 44 | 7.9 | 0 | 7.9 | 0 | 7.9 | -0.8 | 7.9 | 0 | 7.95 | 0.8 | 7.99 | 87.8 | 8.05 | 57.3 | 8.11 | 2370 | 7.76 | 2470 |
8.21 | 6080 | 8.21 | 211.28 | 8.26 | 44 | 8.32 | 0 | 8.32 | 0 | 8.32 | 0 | 8.32 | 0 | 8.37 | 0.8 | 8.42 | 87.5 | 8.47 | 56.9 | 8.52 | 2350 | 8.16 | 2440 |
8.63 | 6240 | 8.63 | 212.89 | 8.67 | 44 | 8.71 | 0 | 8.71 | 0 | 8.71 | 0 | 8.71 | 0 | 8.76 | 0.8 | 8.82 | 87.5 | 8.87 | 57.3 | 8.92 | 2330 | 8.57 | 2430 |
9.02 | 6360 | 9.02 | 212.31 | 9.06 | 44 | 9.1 | 0 | 9.1 | 0 | 9.1 | 0 | 9.1 | 0 | 9.16 | 0.78 | 9.2 | 87.5 | 9.25 | 57.6 | 9.3 | 2310 | 8.97 | 2390 |
9.39 | 6440 | 9.39 | 216.11 | 9.44 | 44 | 9.5 | 0 | 9.5 | 0 | 9.5 | 0 | 9.5 | 0 | 9.55 | 0.79 | 9.6 | 86.7 | 9.64 | 57.6 | 9.69 | 2290 | 9.35 | 2390 |
9.8 | 6560 | 9.8 | 219.61 | 9.85 | 45 | 9.88 | 0 | 9.88 | 0 | 9.88 | 0 | 9.88 | 0 | 9.93 | 0.8 | 9.98 | 86.3 | 10.03 | 56.9 | 10.08 | 2270 | 9.75 | 2390 |
10.18 | 6680 | 10.18 | 219.03 | 10.23 | 45 | 10.27 | 0 | 10.27 | 0 | 10.27 | 0 | 10.27 | 0 | 10.32 | 0.79 | 10.38 | 86.3 | 10.42 | 57.3 | 10.47 | 2250 | 10.13 | 2350 |
10.59 | 5920 | 10.59 | 194.19 | 10.64 | 45 | 10.68 | 0 | 10.68 | 0 | 10.68 | 0 | 10.68 | 0 | 10.73 | 0.92 | 10.78 | 18.8 | 10.83 | 0 | 10.87 | 430 | 10.53 | 2310 |
10.96 | 5040 | 10.96 | 19.08 | 11.01 | 45 | 11.06 | 0 | 11.06 | 0 | 11.06 | 0 | 11.06 | 0 | 11.11 | 0.93 | 11.16 | 9.8 | 11.2 | 0 | 11.24 | 290 | 10.91 | 2180 |
