Light bulbs in front and rear domes and footwells???
Ghost001
Does anyone know what interior light bulbs are in the:
1. Footwells
2. Front Domes
3. Rear Dome
4. Above the sun visors?
as i want to change them but dont know what fitment size they are?
Ghost001
The Dome lights are 501 or W5W. Not sure what the footwell lights are yet haven't got to them yet.
zee
I knew you'll eventually find it and post up. I had read a thread on where someone installed LEDs..but can't find it at the moment.
Ghost001
The bulbs are the 5w5 or 501 for the footwells but as on the mk5 the bulb out warning lamp comes on because of the low power consumption of LEDS. so either change for a normal bulb or need to get a LED with a resister in series. for it to work.
dstill
I've changed my footwell lamps for LED's and they have'nt activated the lamp out warning light on the dash. They dont have resistors neither. I tried them in the number plate lights (same type of bulb) and they did activate the lamp out warning.:(
Nicks06TR
can we get some pictures posted of these replaced lamps? Also, would it look terrible to replace with red bulbs? I thought it may look sweet, maybe just for the visor lamps, and white everywhere else.
p3asa
Hi guys, came across your thread when searching how to remove the footwell bulb.
I've basically taken the bulb holder out but it is enclosed by a metal box. I've tried plying that with a screwdriver but it won't part. Is there a trick to remove the metal box?
Also is there any trick for removing the front dome to change the lights?
Cheers
dstill
Cheers
Hi, i changed mine, i was surprised when i found they were enclosed in a metal case. I gentally prised the box out without damging it and replaced the bulb. Just be careful and you will get into it.:)
One thing though, i put Led bulbs in, the ones that the leds point straight forward. You will be better off with the 360 degree bulbs with leds all around the head. Alternatively you can get a flat type with the leds pointing out of the side if you know what i mean.:w00t:
p3asa
Thanks. I hadn't even thought about that but it makes sense now you have mentioned it.
Have you changed the front dome? Changing my rear has made a big difference to the car.
zee
I found this picture of a Mk5 R with LEDs installed. Really looks good.
