List of Popular MKVI VAG-COM Tweaks
Mostic
Hi Guys,
I have a problem with the Telephone, everything is working perfect except that I hear the voice of callers low -but it is clear- even when I increase the volume to the maximum I still hear them a bit low.
Do you have any code or settings that can help.
Thx
Here are the details:
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 L HW: 1T0 035 680 C
Component: RNS-MID H41 5269
Revision: AB001001 Serial number: VWZ6Z7K5238074
Coding: 04050402040000900000
Shop #: WSC 01357 011 00200
VCID: 373EEB9A86A907FA4D-8062
Subsystem 1 - Part No: 7L6 919 859 G
Component: AUNZ V7 8035
No fault code found.
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 J HW: 7P6 035 730 J
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007662981511
Coding: 0210000000010110
Shop #: WSC 00015 115 12345
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 393AEDA2B8BD118ABB-806C
brobst
Hi Guys,
Thx
Have you adjusted the settings on the phone itself.
Sent from phone Tapa
ahard48
Also just noticed a "problem". Had coding done for DRL on/off via MFI. Bought deAutoKey city lights, went to turn the DRL on via MFI and nothing comes on. Tried turning them on, restarting car and still nothing... seems as if they are always off but remember when first coded I manually turned them off via MFI.
Any ideas.
Edit: NVM, my dumbass had the ebrake on...
brobst
Yeah I was talking about the physical cell phone. It has internal volume and the car also has bluetooth volume.
Idk then, hopefully someone else can chime in
cav1982
Do you mean increasing the volume from my mobile phone? If that what you mean then the answer is yes for sure I have it to the maximum.
If the question is about another thing, then I don't know what you are talking about! :)
I'm having the same problem with phone calls and the Voice command prompt voice. VW told me that I have to replace the head unit. Been using my phone speakerphone instead. Can't justify spending that kind of cash. Have another quick question maybe someone can help with.
Anyone know how to get this to work with OBD11?
-- Steering Wheel Push-To-Talk Button as Mute
Description: Converts the push to talk button your steering wheel into a mute button.
Uncheck bit 3 of byte 1 under Steering Wheel Long Coding Helper
Pic tutorial: Steering Wheel Push-To-Talk Button--
I believe the 'Steering Wheel' (16) is labeled 'Steering Column Electronics' in OBD11, but when I hit coding I only have the option of adding a new value (currently 0000732) and not individual bytes and bits. If I do have to put a new value in what would that be? Would appreciate any help. Thank you.
jjohns1508
Door lock timer
Hello, Is there anyway to extend the time it takes for the doors to relock after I unlock them if they are not opened. I think it is around 30 seconds now, and very frustrating sometimes.
brobst
Idk if a code exists, but if you open and shut a door, then they will not automatically lock.
BuiltforSin
Windows: Roll Up/Down with Key
Description: Roll down down your windows with your key remote when you unlock the doors
Check bit 5 of byte 3 in Central Electronics Long Coding Helper
Option: If you want to be able to do this when the car is turned on, check bit 7 of byte 3
Option: Enable your lock switch on the door to roll all windows up/down without a key present, check bits 3, 4, and 7 of byte 3
Pic tutorial: Comfort Closing/Opening via Remote Control
Only my driver side window rolls down when I hold the unlock button on the remote. Shouldn't both roll down?
cav1982
Hi just switched out my stock 17" denvers on my '10 GTI with stock 18" serrons I just purchased off another vw user. Have tpms sensors in both, but still getting a flashing tpms light in dash. This being a '10 model it doesn't have the tpms reset button in the glove box that later ones came with. Can I reset it to work with my new set or do I have to disable it completely? Any help on how to do either would be appreciated.
brobst
Yes. Double check the changed bits.
Also, do you have your passenger window set to auto down when you tap the window switch?
Maybe unlock all doors first before holding to roll the windows and see if that fixes it.
BuiltforSin
Passenger is set to auto-down, and I tried unlocking both doors before holding. I'll have to go back and see if I clicked all the bits tomorrow.
