I have been chipping away at a master list of popular VCDS tweaks for the MK-
6 and I figured it'd be good to share them here.
Some of the the information below is my own discovery, but most of it has been scavenged from several threads across several forums.
The problem with every VCDS thread I've seen is that you have to dig through 10+ pages to see all the tweaks.
The information is usually often not provided in a standardized format, so people are not always clear on where to find stuff.
As new tweaks come are discovered, old threads are not updated.
Ross Tech has much of it on their site, but again, it does not contain all of the tweaks below.
My goals with this thread are to provide the data in a standardized format,
and to keep this first post update with all of the MK-
6 VCDS tweaks added to the thread, as well as any others I discover or come across.
The hope is that people don't have dig through the whole thread to find what they are looking for.
I am also reserving the second post for VCDS retrofit coding.
I have not collected most of that data yet, but will begin filling in as time permits.
Lighting:
Coming Home Lights
Description: Coming home activation requires you to pull the high beam stalk back briefly after shutting the vehicle off and before exiting.
This will turn on your lights for a set period of time after you get out of the car.
After this is enabled, it can be turned on/off in the MFA, and you can adjust the time period.
Leaving home function requires an auto switch and light sensor.
Check bit 2 of byte 12 in Central Electronics Long Coding Helper
Pic tutorial:
Coming Home Lights
