I'm hoping somebody has an answer for me. I've searched Central Electronics with VCDS, google, and forums.
I've coded both of my VWs, 2 door MK6 Golf and MK6 Jetta, for comfort windows via remote. When I close the windows with the remote on the Jetta, the turn signals/indicators flash once immediately after pressing the lock button and also once the windows are completely closed for confirmation. My Golf only flashes the indicators once when first pressing the lock button.
I would very much like to have this "windows closed confirmation" feature on the Golf.
Perhaps its the control module as my GTI flashes with windows closed confirmation
sent via carrier potato
What i'm doing wrong ? I want to have to lock/unlock confirm by Horn (via VagCom), but it doesn't work. Help ?
I've had the emergency braking enabled on my car for a while, but I've never seen it happen. I stood outside while my dad drove it and braked, and it didn't come on. It was full braking from 80MPH. Does anyone else have an issue with it not working?
It works for me only ever activated when testing on a bad road with plenty of slip. If the abs isn't working at its maximum you won't get the lights.
Hmm... I guess I'll have to try again on a road that's a bit slipperier. Also if you have the box checked for the hazards to flash, do you have to turn those off after the emergency stop or does it just cancel when you start moving again like the brake lights?
If you don't come to a complete stop they will turn off by themselves as soon as you are moving again. If you brake to a complete stop they will stay on until you hit the hazard button to turn them off.
You don't need to be slipping for them to activate, but you do have to brake HARD. Like ABS is in overdrive hard.
