Lower timing chain cover front crankshaft seal
funkymcbain
Quick question for you guys, I damaged my front crankshaft seal while installing my lower timing chain cover. Is it possible to yank that little seal out without having to change the entire lower cover again? I found the PN 06L103085B.
funkymcbain
This seal is at the front and there is no real crankshaft to scratch.
Grabbed the seal with a pair of pliers, leveraged it against something and out it popped. Pushed the new seal in, went around it with a bit of a hammer and bobs your uncle.
