peak MAF values do not matter as that may indicate a spike. I still say to this day that the Unitronic true 3" design led to the best airflow readings and fuel trims.
Did you compare it to the IE intake?
I really loved to see a comparison between the two.
Yes, no one should be posting peak MAF. My K03 w/ stock intake peaked at 200 g/s but steady readings were at 189-190 g/s (~345 CFM).
K04 on an ultra mild base tune right now is ~268 g/s @ 6500 RPM (~485 CFM) (no downpipe yet, on its way...not sure if this affects anything) w/ Carbonio intake.
here is my log
APR V3.1 98RON 4th gear full throttle
298 g/s
Is this an AP tune?
Nice! Out of curiosity..have you dyno'd your car? If that 298 g/s is repeatable back to back...that's impressive. And to second FriggenT's question which intake do you have? Also, is your turbo port and polished?
To clarify that, I've read that a pound of air per minute roughly equates to 10 hp. So 298 g/s = 39.42 pounds/min (according to this) = roughly 394 hp....not sure if there's much truth to that or not, but Garrett said so. Hopefully I'm not confusing volumetric air flow with mass air flow.
"As a very general rule, turbocharged gasoline engines will generate 9.5-10.5 horsepower (as measured at the flywheel) for each lb/min of airflow. So, an engine with a target peak horsepower of 400 Hp will require 36-44 lb/min of airflow to achieve that target. This is just a rough first approximation to help narrow the turbo selection options."
The conservative estimate (x9.5) puts you at~375 hp.
298 g/s seems quite high...I haven't seen that with any k04 that I can recall...not saying it's not possible, but the intake and p&p I'm curious about.
I'm suprised by 298 too. Maybe the condion is superb at that night.
APR Carbonio intake, APR 3inch full exhaust.
