g-magoo
Long time lurker, but I'm finally getting to the point where I want to keep track of what I've done to the car and I prefer forums to FB. Photos are below for the filthy casuals that want to skip all the reading. Apologies in advance for the parentheses, it's just how my writing process works.
I've been around VWs most of my life thanks to my dad; personally owning 3 aircooled when I was in/just out of high school ('73 Super, '58 Standard, '62 Ragtop and worked at an aircooled resto shop during that time period), two mk3 jettas, G60 swapped mk2 jetta, and a stupid-ass 1.8t swapped mk4 golf on BBS that was far too low. I always found the MK6 to be one of the best looking GTIs and when my current vehicle at the time (2017) decided to give up the ghost, this CPO base '14 GTI popped up w/ 28K (currently at ~72K). It was kept stock for the better part of three years (aside for some OEM led tails... priorities) while the wife and I moved a few times and had our first kid.
That being said, I'm not sure how often or special the updates will be in the immediate future. Too many projects/ideas, not enough time. Below is what I can remember doing so far:
Engine -
Cobb AP/Stratified tuned
APR ignition coils
Go Fast Bits DV+
Integrated Engineering Intake
Drivetrain -
034Motorsport billet pendulum mount inserts (upper/lower)
Suspension -
H&R sport springs
Koni yellow shocks
Front subframe collar kit
OEM S3 LCA bracket bushings
Audi TT front strut mounts
Veltsport rear shock mounts
New OEM bushings, ball joints, etc through-out when above was completed
Brakes -
Stoptech street pads
Geomet slotted rotors
Tyrolsport stiffener kit
ATE Super blue
Wheel/tire -
Neuspeed RSE10, 18x8.5 ET45
Indy Firehawk, 255/35/18
Exterior/Cosmetic -
OEM Cherry Red LED tail lights
Color matched lower bumper panel
Interior -
Not a damn thing aside from monster mats
Projects/parts to be completed/installed when I find the time:
OEM HID headlights needing lens replacement (just need to commit to tackling it)
Rear subframe collar kit
S2T paddles, B1 silver (willing to sell these, as I'd really like a black pair)
East detailing suede wheel wrap
Replace headliner with foam backed suede
2 step polish/ceramic coating
Future plans include getting the stuff above done, plus maaaaaybe getting some track time in and prepping the car to reliably handle the stresses of track time in the FL summer. Below are some of the bigger near future plans, engine/drivetrain mounts and camber taking precedence; probably X-mas presents for myself.
- Engine mounts are most definitely due to be replaced. Obviously stock isn't going back in, and see a bunch of people say BFI... but at that price point, why not go with 034 billet streetsport mounts? Is it because more people have BFI and can vouch for them, or did 034's failure prone density line chase people away? Dogbone mount : is a new OEM one with 034 inserts enough or am I asking for a bad time? Always had my eye on the APR mount.
- Adding camber to the front (currently at -1.0F/-1.7R), wavering on superpro ball joints vs. camber plates. I've held out on installing the rear deadset kit and subsequent alignment until I figure out what direction I want to take. Both have their merits, one has a fixed amount of camber but adjusts the roll center a bit vs. the plates with actual camber adjustability, but no roll center correction.
- Engine and dsg oil coolers, probably mounted behind where the fog lights currently reside. Not sure if I want to go the Mocal t-stat sandwich plate or the iABED plate route, probably Mocal. Then there's the task to find something similar to USRT's icecap, due to it having been "back-ordered" for forever. Would prefer something stateside, but I know bar-tek has one. Cooler wise, looking at Improved Racing's MHX series. I've seen them mentioned on here and FB a few times with good feedback.
- Definitely want to do the brakes over as I've never really been happy with the way the brakes feel, probably go with the Macan set-up over the Golf R/PP. Then comes the potential master cylinder hassle when upgrading calipers.
Any feedback, comments, pointers, conversation, etc. are welcome. Thanks for making it this far, I've drawn a lot of inspiration from numerous members and their/your builds on here.
How it currently sits photo-dump.
Engine -
APR ignition coils
Go Fast Bits DV+
Drivetrain -
Suspension -
H&R sport springs
Koni yellow shocks
Brakes -
ATE Super blue
Wheel/tire -
Exterior/Cosmetic -
Interior -
