MFactory Coilovers for GOLF MK6 - Sponsored Drivers Required
Status
Not open for further replies.
MFactory
GolfMkV Sponsor
Hey Guys,
after researching the various coilover setups currently available on the market, we've noticed there is a gap in the market for a setup that is:
1) Offers premium real-world features, at an affordable price point
2) Offers local (North American and European) facilities for rebuild and servicing
there are a lot of generic setups available on the market at the moment, however, they are basically all the same/similar setup (i.e generic) and have not changed over the past 15 years, with prices ranging from $1000-2000; the more expensive only being due to the "brand" and the "assembled in XXX label" rather than the design features (the components are all still manufactured in China, Taiwan or Korea)
of course, rather than reinventing the book, it is best to stick to tried-and-tested designs (especially for the street car) hence why all the current setups available are similar.
because of this "gap", we at MFactory have decided to do what we do best, and this is to provide you guys with a quality solution that meets our #1 priority; Value for Money. Whilst this new project is still in it's infancy, we want to take this opportunity to design, manufacture and offer our solution based on your feedback and not just what the "marketing folks" think you want!
so our project as it stands today:
YCW Reference Series Coilovers
- Spec'd for Superior Performance
- Priced for Affordability
- Over-Engineered for Comfort & Safety
FEATURES:
Forged 6061-T6 Hard Anodised Aluminium Front Upper Mounts
- Strong and Lightweight, our Forged Upper Mounts are Hard Anodised for superior Corrosion Resistance
Forged 6061-T6 Hard Anodised Aluminium Rear Upper Mounts (Where Applicable)
High-Tensile Carbon Steel Front Camber & Caster Plate with Anti-Slip Coating (MacPherson)
- CNC-Machined High-Tensile Carbon Steel supports more load than lesser-quality mounts
- Camber Angles can be adjusted precisely to your driving needs
- Where space permits (Application Dependent), Caster Angles can also be fine tuned
Oversized PTFE-Lined Japanese Spherical Upper Mount Bushing
- Increases shock articulation and prevents coil-bowing
- Higher load rating for increased durability
- Minimises knocking noise associated with lesser-quality bearings
Forged 6061-T6 Hard Anodised Aluminium Upper Spring Perch with Sealed Japanese Radial Bearing
- Strong and Lightweight, our Forged Upper Spring Perches are Hard Anodised for superior Corrosion Resistance
- High Quality Sealed Japanese Radial Bearing removes rotational stress from the upper mount and is sealed from the elements
62mm ID Cold-Wound Japanese SAE 9254V Chrome-Silicon-Vanadium Steel Linear Springs
- Custom-made for us in Japan from the highest quality Japanese-grade spring steel, using proprietary manufacturing processes
- Not all springs are manufactured the same. Lesser-quality, Taiwanese-manufactured springs offer inferior performance and durability
- Although more expensive, we believe the increase in performance more than offsets the marginal increase in manufacturing costs
OEM-Balanced Spring Rates
- The majority of budget coilovers currently on the market offer default spring rates that deviate from the oem-balanced spring rates
- By not accounting for Motion Ratio Calculations and just replicating race-car setups, this results in a very unbalanced and uncomfortable ride on a Street Car
- All Reference Series Coilovers are supplied with oem-balanced spring rates, offering you increased performance without sacrificing ride comfort
62mm ID Cold-Wound Japanese SAE 9254 Chrome-Silicon Steel Helper Springs (Application Dependent)
- Optional Helper Springs can be used to increase droop travel
52mm OD Cold-Drawn Japanese SAE 1020 Seamless Carbon Steel Shock Body
- Offers superior physical properties and strength-to-weight ratio over lesser manufacturing processes
Black-Zinc Plated Fully-Threaded Shock Body with 250hrs of Salt-Spray Testing
- Offers superior corrosion-resistance
14mm OD or 20mm OD (MacPherson) Forged SAE 4140 Chromoly Steel Piston Rod
- Monotube shocks, although offering increased performance over Twintube shocks, have an inherent weakness; a load-bearing Piston Rod
- Although Inverted Monotube Shocks are touted as the solution, these come with their own set of problems, not least the substantially increased cost of manufacture
- Our over-engineered solution to the problem, with only a marginal increase in manufacturing costs, is our proprietary Chromoly Steel Piston Rod
- Offering a substantial increase in tensile strength over lesser-quality rods, not only does this keep costs down, it significantly increases product safety
Oversized Piston Rod Guide
- A common issue with the majority of budget coilovers currently on the market is performance-sapping deflection and shaft-play, even after only limited usage
- Through the use of our proprietary Piston Rod Guide, this minimises deflection and shaft-play, allowing you to reap the performance benefits for a longer period of time
7-Level Rebound Adjustment
- Our Reference Series Coilovers allow 7 levels of Rebound Adjustments, allowing you to fine-tune your vehicle comfort and handling
- Unlike the majority of budget coilovers currently on the market, with their 30+ Level Adjustments, you can physically feel the difference between each adjustment
- In this particular case, more is not better; it's simply an inconvenience and setup-nightmare
10cm/15cm/20cm Length Adjustment Extenders (Optional)
- Designed for vehicle applications with limited access to their upper strut mounts
44mm OD Forged 7075-T6 Hard Anodised Aluminium Digressive-Blow-Off DBO Piston™
- Over-engineered for superior strength, with anti-stiction and anti-friction properties
- At lower shock speeds (Cornering), our DBO Piston™ maintains a higher damping force, offering increased responsiveness and stability
- At higher shock speeds (Bumps), our DBO Piston™ maintains a lower damping force, offering increased comfort and control
Performance Synthetic Damper Oil with High Viscosity Index and Proprietary Additives
- A proprietary formula providing consistent damping over a wide temperature range and superior anti-stiction/anti-friction properties
Viton Performance O-Rings
- Upgraded O-Rings offering better performance and durability than lesser-quality Rubber O-Rings
Forged 6061-T6 Hard Anodised Lower Spring Perch Locking Collar
- Strong and Lightweight, our Forged Locking Collars are Hard Anodised for superior Corrosion Resistance
- 1pc Locking Collars, providing secure and hassle-free adjustments
Fully-Threaded Forged 6061-T6 Hard Anodised or High-Tensile Carbon Steel Lower Mount
- Threaded Lower Mounts allows us to use a longer shock body for increased performance
- Shock Stroke is unaffected by Ride Height changes
- Allows an increased Height Adjustment range
PTFE-Lined Japanese Spherical Lower Mount Bushing (Eyelet Type. Optional)
- Increases shock articulation and prevents deflection
Silicone Lower Mount End Caps (MacPherson)
- High Quality Weather-Proof End Caps for MacPherson lower mounts, preventing water and dirt from entering the the lower shock body
Weather-proof Neoprene Shock Covers
- High Quality Weather-Proof Shock Covers, preventing water and dirt from clogging up the shock assembly
Fully Rebuildable
- Our Reference Series Coilovers are fully rebuildable, with spare parts always in stock and available for purchase
Limited Lifetime Warranty on Hard Parts
- Warrantied against Manufacturers Defects
- Non-Transferable. Registration and Proof-of-Purchase Required
- Hard Parts include: Upper/Lower Mounts, Spring Perches, Locking Collars, Shock Body and Piston Rod
Limited 1 Year Warranty on Wear Parts
- Wear Parts include: Bearings, Springs, Seals and Shock Internals
Local Service Facilities
- North America: San Dimas, USA. Warranty Claims and Rebuild Services available
- Europe: Leyland, United Kingdom. Warranty Claims, Rebuild Services and Revalving Services available
We currently have several "test sets" shipping out to our testers around Late January, and will be updating this thread with our results (along with the dyno graphs)
Sorry for the low quality image. Once the test sets are finished, I will upload better product images:
If you are interested, or require more information, please PM me
Pyotr
Just swapped my suspension on Saturday... definitely still interested though
EDIT: whats the height adjustment on these?
gichoke
Hi Stephen – Thanks for offering more options for our suspension. I have a bunch of questions about these coilovers:
1. Are the shocks monotube or twin tube?
2. Are the shocks rebuildable?
3. Are the shocks made in Taiwan or China?
4. How do you adjust the front shocks: A) on top (engine accessible) or B) on the bottom (reach around the tire)?
5. How do you adjust the rear shocks: A) on top (need to remove the shocks from the car) or B) on the bottom (reach around the tire)?
6. Are the springs linear or progressive?
7. Are there other spring rates available?
8. What is the warranty on the coilovers?
9. What is the height adjustment range?
10. Are sway bar end links included, and if so, are they adjustable?
11. What do you mean by “looking for drivers to help us test”?
clownish
just clowning around
Have you guys tested these in various climates? For example, I went with Bilsteins because I know that those PPS systems last in extreme heat and cold, which is okay for the salt belt in the US. I've seen dozens of cars with these things installed, daily driven, and rarely problems. Vs. nicer coilovers like Ohlins which are more performance oriented and not good at all when exposed to snow, ice, and salt.
Are these more performance oriented and therefore less reliable for daily drivers?
MFactory
GolfMkV Sponsor
Our target market for our custom-spec coilovers is for daily drivers (not race cars), so they will be designed to be fully resistant to weather/salt.
Tuuza
Is this offer available only for US/NA people. I'm atm looking for new set of coilovers for my mk6 GTI . I live in Finland, the land of huge temperature changes and lots of salt on every road so it would be perfect testing-ground for things like coilovers.
Thanks.
Lähetetty minun E6853 laitteesta Tapatalkilla
cbaumy34
Very interested!
Sent from my XT1080 using Tapatalk
Trytun
I'll be swapping out suspension in late February. Very interested in seeing how these turn out. Subbed!
greasyginzo
Why adjustable shock bodies?
I think you guys could be on to something I love everything so far but a few thoughts
Linear springs definietly not progressive. Market is already flooded with progessive spring kits.
4 way adjustable inverted monotubes would be ideal of course but cost could prevent true 4 way adjustments. If 4 way is too costly then 2 way at a minimum even if price needs to be increased.
Lowering range should be minimum drop ie. as close to stock ride height as possible maximum drop 2" or 2.5" (to cater to people who want to get low for the sole purpose of selling more kits) so long as it can be done without increasing the min drop
Love the dust covers on both front and rear dampers
Swift or Hyperco springs would be best simply because of the name.
Customer chosen spring and damper options
About the most popular coilovers it seems the budget kits are most popular Solowerks, FK and the shop branded kits like NGP and USP. I personally have Bilstein B14s and love them.
MFactory
GolfMkV Sponsor
This separates ride-height adjustment from spring pre-load i.e You can adjust the ride-height without affecting the pre-load on the springs. With coilover kits that rely solely on adjusting the spring height, the lower you go, the stiffer they become.
Yes, our springs are linear
As these are being developed initially for the street/weekend market, we need to keep costs down. We have the capability to manufacture 2 ways though with separate reservoir, but these won't be designed until we've established these initial sets
General adjustability will be between stock - 4.5". The advantage of ride-height adjustment via the lower mounts vs the springs
These will be an option
Note: The title of this thread should read "Golf mk6" rather than 1/3/5-Series. The post was a copy and paste from our BMW threads, but pressed Submit too soon. For some reason, the edit function on the mk6 site is buggy
Status
