Hi there everyone!
I own 2011 GTI MK6 with 180k km on the clock which had some misfires for a while and I finally started to try to solve it.
Symptoms
Engine misfiring, especially when it's cold (even more in cold weather). I am not getting any check engine lights/codes, but I can see the misfires via VCDS in all cylinders, but especially in cylinders 2 & 3. It is not happening all the time, but most of the time I can provoke it by slightly pressing the accelerator and keeping RPMs around 2k, then the car starts shaking and I see misfires happening via VCDS. In usual driving I can feel the misfires in slow speed situations, when the accelerator is slightly pressed down (traffic, shopping mall parking).
Things I've tried
Do you guys have any tips on how could I test these out without replacing everything and hoping for the best?
Any help would be appreciated,
Thanks.
Symptoms
Things I've tried
- Changed spark plugs to Bosch - no change, half year later to NKG - no change
- Changed the coil pack - no change
- Carbon cleaning - cleaned, guys said that valves were in good condition before cleaning - no change
- Found used injectors on cylinder 2&3 (probably previous owner was searching for answers as well), changed all four to new ones - no change
Thanks.
