Mk6 Boot is leaking
mcfaddenmkvi
The video shows it leaking into the light which could be a seal or the light isn't secured tight enough or may have a crack. Trunk leaks are usually a seal being bad or blockages in the channels that water runs through to get off the car. VW would replace if under warranty still
golfgti_tr
I think your rear spray hose is broken. You need to remove the panels and see where it leaks exactly. To remove these panels is pain in ass. Good luck!
