interweb42
2012 MK6 gti with less than 60k miles on it. I recently did a brake job, pads and fluid. Blead system by doing vcd ABS bleed procedure and manual 2 person method for rears.
Pedal feel is good but when I press on the pedal hard and hold down continues to sink like a blead valve is open (won't pump up to firm). When car is off pedal pups up and stays firm. (might go down a bit if I press really hard)
(unsure if it was doing this before brake job)
I Re-checked all the pedal bleed valves and no leaks, fluid level steady in MC. Re-did ABS bleed procedure and issue still exists? :mad0259:
I've read quite a few posts like this and everything seems to point to a defective MC?
Any suggestions would be greatly appreciated
Thanks,
Dan
Thanks,
Dan
