Mk6 multifunction buttons
Dastan
I got a multifunction button for your mk6 steering wheel $150 , you can reach me via text only 858 366 5646
Sent from my SM-G900T using Tapatalk
realcyberbob
Do you happen to know a DIY to install this on a base GTI with no buttons? I can't seem to find one. Not sure if it's a direct swap or if other parts are needed.
Dastan
I've had it on my base gti, you just have to snap out the airbag and screw them in, you're car already comes with the wiring
realcyberbob
Dastan
YOUR STOCK GTI COMES WITH THE HARNESS AND CONTROL MODULE!!!!!!! all you need is plug it in!!
nadams5755
I suppose whether or not it works "out of the box" as you describe depends on whether you already have a dsg transmission? I get the impression from the link above that he has a manual car and had to add the tip tronic module.
