Id would ditch the APR Tune also. My 3 experiences with Stratified have been great. I'm about to have a 4th.
I also passed emissions with the previous tunes if that's a plus for you IDK.
Noticeable gains cost money no way around that. about 900ish to re-tune the car probably.
All K04 cars are all cookie cutter builds pretty much. you have the same mods as everyone.
I like this recommendation for water meth and a pro tune from someone at least you will have a verry noticeable TQ gain, and the car will feel faster.
IMO Aux Fuel is a Hack fix for fueling. When the aftermarket wasn't fully there sure but now it's different. Plenty of fueling options.
But its $$ for a K04 car when you're not going to need it. Unless your adding Ethanol.
K04 can mostly be maxed out without extra fueling mods. With water meth you can push it a bit more.
The aux fuel kit is great... it sprays fuel (even has a bung for future water meth if you want) into the throttle body... cleans the valves and adds port injection. Its a big injector... about 950cc iirc. If you upgrade the low pressure fuel pump to make sure you have more headroom for total fuel, it makes running an ethanol tune viable. It's also great for fueling a bigger turbo. That's why I went with it.
Otherwise, you have to upgrade the HPFP which only has one option to upgrade on ea888.1 motors (nostrum) and then upgrade injectors. Its not as cool as going port injection.
If you're really going for power, then consider getting an intake manifold setup with 4 injectors, but then you'll need a really solid lpfp upgrade (450lph or something).
My point is... aux fuel kit is plenty for pushing the stock bottom end (420-440whp)... and it cleans your valves
Aux fuel kit is 975 + 425 (with lpfp upgrade) for a total of 1400
The nostrum hpfp costs close to 900 iirc, and mk7r injectors from FCP will be close to 300 for a set, so 1200, but you'll still need to upgrade your LPFP since that starts to run out around 350whp mark... especially if you want to run ethanol which uses more fuel... which would cost you more than just the aux fuel and lpfp setup
