Rob_d91
Had a master/slave failure a few weeks ago (89k miles) and decided to have the SB stage 2 daily SMF “quiet” version installed same time. Total for clutch pack, rear main, master, pedal bushings and a power mirror switch: $3,184. About 200 gentle break in miles later and I decided to give it some low rpm throttle (stock tune) and the thing turned into a tractor for a couple seconds while pulling normally in 5th gear 1800-2300 rpm. Really aggressive NVH each time I start to build low rpm boost. I’ve had poly engine mounts in mk5 r32 and poly dog bone/engine mounts in mk6 gti and this felt similar to throttling those cars but I’m with factory mounts. I’ve read everything from the SMF is normal sounding with high gear lash noise and NVH, to there must be something wrong. I can’t seem to get a good idea of wether or not this is ok. Hoping others with similar experience can chime in. Thanks
