My timing chain jumped a tooth, and I think my mechanic and dealership are partly to blame. What to do next?
blinker_fluid
I got this 2014 GTI 6 months ago. 65,000 miles on it. My first "new" VW so I admit I'm not the most knowledgeable about it. I did a manual carbon cleaning, had the injectors professionally cleaned, replaced the spark plugs and coil packs, and several other minor things. But as you can see if you look at my previous post here, I was still chasing some misfires. Nothing I found online pointed me to the timing chain. Nobody I talked to mentioned the chain as a possible culprit for misfires. I even brought it to a local Volkswagen mechanic (VW master technician - decades of experience) who told me that there was nothing wrong with the car, despite the misfires. Then, last night, it started very hard and would barely stay running. The car was shaking. The CEL was blinking. I checked the codes - P0016.
So after reading some horror stories about the P0016 code, and given how the car is running, I'm certain that the timing chain skipped a tooth. The fact that it still ran (terribly, but still) tells me that maybe it only jumped 1 tooth and MAYBE the engine isn't trashed.
Also, the first thing that I did when I bought this car 6 months ago was take it to the local VW dealership and asked for a used car inspection. They told me it needed things like a break fluid flush, a new oil pan... but they said nothing about the timing chain or tensioner. I have the printout from that inspection (it doesn't specify that they were checked, but it doesn't say anything about them being bad). And, again, I took it to a local mechanic and pointed out the misfires, and he told me that the car was fine. Of course, I didn't get that in writing, so that's not going to get me anywhere.
So what would you do if you were in my shoes? Even though I knew it wouldn't do any good, I called my insurance company who told me to file a claim before letting anyone do any work on it. And I called VW of America, who started a case and told me someone would get back to me on Friday. But I don't expect them to go out of their way to help either. I figure if I try blaming the mechanic or the dealership for missing the signs of the timing chain/tensioner wearing out (the misfires) they'll tell me to take a hike. I feel like I don't have much of a leg to stand on with the mechanic, and I doubt the dealership would willingly do anything for me.
Also, would you even bother putting money into trying to fix this engine, even if it shows no signs of damage? Or would you automatically go for an engine swap? I saw another post where a guy paid for the new chain and tensioner (which wasn't cheap labor) because he couldn't find any signs of damage, and he still had to swap out the engine later because problems kept coming up.
Thanks.
Joe_Mama
A 2014 has the updated tensioner so you don't have a leg to stand on.
You can either buy a new timing kit and hope for the best or you can source a used TSI motor.
blinker_fluid
You should be covered under the extended warranty, no? Do you not live in the US?
I thought the extended warranty was only for 2011 and 2012 models. Since 2014 has the new tensioner, I don't think I got the extended warranty. Is that incorrect? It's ironic, though, because I specifically looked for a later model because I thought they had fewer issues. But if I had gotten an earlier model, I'd be covered for this. It seems like sometimes, you just can't win.
Joe_Mama
That sucks dude. Did you or anybody at any point check chain stretch through OBD?
same thing i thought but its such low mileage for stretch. must have been oil starved by previous owner or something
blinker_fluid
Not to my knowledge. I didn't know that was something that could be checked through OBD. This is why I brought it to the VW mechanic and the dealership - I thought they'd know what to look for.
blinker_fluid
I just checked the oil. It's full. I never saw an oil pressure warning light either.
EDIT: Oh, I just realized you might have meant that it was historically oil starved, which may have led to premature stretching.
supreme_gti
Most shops will want you to come back with a dead engine so they can make more money off you. So don’t ever expect any shop (VW dealer or euro shop) to give you a heads up, unless they know you and care for you.
at this point, you can get a engine from a scrap yard or other ways. I would go down this route. Or you can try fixing it.
most guys I know that have the 2.0T with the timing chain tensioner and chain failure get it replaced before it goes wrong (skips and bends the valves).
as a consumer. We must do heavy research on anything and everything we buy, especially vehicles…
I got the timing tensioner and chain and other components replaced before it was too late.
Make sure you go to a VW/Audi experienced shop.
ask them to give you advice on the weak spots of these engines (2.0T Audi).
use the internet to figure out what should be fixed. Tons of videos on YouTube.
find yourself a good VW/Audi mechanic/shop, you’ll save money and time.
good luck.
blinker_fluid
good luck.
Thanks for the advice. I agree that the mechanics and dealerships may not have my best interests in mind, and there's no way of knowing for sure that I'm not going to have further issues with this engine. So, as much as it would suck to do an engine swap, I feel like putting time/money/resources into this engine may be a waste and just cost me more in the long run. But the fact that the engine does still turn over and run (even though it runs badly) makes it tempting to try to save money by just putting a new chain/tensioner on. However, I don't know if I'm up to that task, so I'd probably have to pay someone and that's not cheap.
To your other points, I tried to research this car as much as I could when I got it. As you can see from my other post on this site, I was reaching out for help and doing as much work as I could on the car. I brought it to multiple places (dealership, VW master technician, etc) so it's not that I wasn't trying to do the right thing. I feel like I was let down by both the dealership and the private mechanic.
Joe_Mama
blinker_fluid
Try another shop? It may not necessarily be the timing chain. Here's the rosstech link with various possible causes for p0016 and some TSBs and diagnostics info under the special comments but manually checking the timing may be out of your ability.
http://wiki.ross-tech.com/wiki/index.php/16400/P0016/000022
Thank you! I did not know that there were other reasons for the P0016 code - I assumed it had to be a jumped tooth. I will definitely have someone look at it.
GolfRfrontend
Used car inspection only focuses on mostly safety stuff. I.e tires, brake, lights and seat belts.. and maybe a vehicle scan. If you wanted timing chain or belt inspection that’ll be additional cost to you.
blinker_fluid
Since it can cause such catastrophic problems, I wish someone had offered to check it for me for additional cost. I told them that the car was new to me and I wanted it inspected to know if anything was wrong with it - they then suggested the used car inspection and didn't offer any other options. Technically speaking, maybe they weren't in the wrong, but I feel let down.
