Need some spacer and tire size help
mk6gti!
I got wheels that are 18x8 et 50.
I don't want to rub but I'm at 24.25ftg, lowest on Konis.
Should I go with 215/40/18 or 225/40/18?
And what about spacers? Is a 8mm front and 10mm back with 3 degrees neg camber help?
Thanks guys. Appreciate the help.
hippiesrock03
yeah your offsets will be flush with those spacers, and get 215/40/18 for no rub. you don't need -3 at the back -2.7 will be enough.
Would this apply even on hard corners or a full car? I have the same wheel size and offsets going in soon.
nvturbo
Go with 215/35/18s. If you happen to need the fenders rolled, HMU.
mk6gti!
I'd rather run 225/40, and I need the spacers so my bolts fit. Would rolled fenders help on hard turns? I got a k04 so I drive plenty hard
iPanir123
Can you run smaller spacers? Reason being you'll be nearly at a 40 offset which is going to be too flush
