Need VAGCOM help!
Tecni
Vehicle: 2013 Golf R Base model
Symptoms: flashing slip, ABS and TCS. Constant on: brake, TCS, and steering.
Car drives perfectly. However, my adaptive steering is not working and I doubt my ABS is either.
I tired to recode the ABS but it won't register a new long code. It indicates: "out of range".
Fault codes:
Friday,01,November,2013,21:32:51:03285
VCDS Version: Release 11.11.6 (x64)
Address 03: ABS Brakes Labels: 1K0-907-379-60EC1F.clb
Control Module Part Number: 1K0 907 379 BL HW: 1K0 907 379 BL
Component and/or Version: ESP MK60EC1 H31 0152
Software Coding: 00000000000000000000000000000000000000
Work Shop Code: WSC 01357 011 00200
VCID: 7DDF303BE4FDBBF04BD
4 Faults Found:
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 167
Mileage: 1048575 km
Time Indication: 0
Date: 2014.14.15
Time: 21:23:59
Freeze Frame:
Count: 3
Count: 0
Count: 20992
Count: 195
Count: 44288
Count: 0
Count: 0
Count: 0
01435 - Brake Pressure Sensor 1 (G201)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 167
Mileage: 26324 km
Time Indication: 0
Date: 2014.14.15
Time: 21:23:51
Freeze Frame:
Count: 3
Count: 2
Count: 29184
Count: 279
Count: 44288
Count: 0
Count: 0
Count: 0
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 167
Mileage: 26324 km
Time Indication: 0
Date: 2014.14.15
Time: 21:23:51
Freeze Frame:
Count: 3
Count: 2
Count: 29184
Count: 295
Count: 44288
Count: 0
Count: 0
Count: 0
01423 - Lateral Acceleration Sensor (G200)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 167
Mileage: 26324 km
Time Indication: 0
Date: 2014.14.15
Time: 21:23:51
Freeze Frame:
Count: 3
Count: 2
Count: 29184
Count: 270
Count: 44288
Count: 0
Count: 0
Count: 0
Friday,01,November,2013,21:38:33:03285
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Control Module Part Number: 1K0 909 144 P
Component and/or Version: EPS_ZFLS Kl. 251 3305
Software Coding:
VCID: 3753E213464151A0D11
1 Fault Found:
03803 - Steering Angle Sensor for Steering Aid
005 - No or Incorrect Basic Setting / Adaptation - MIL ON
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Mileage: 26324 km
Time Indication: 0
Date: 2014.14.15
Time: 21:12:53
Freeze Frame:
Battery Volts: 12.4 V
DD
Temperature: 36.0°C
Count: 3
Steering Angle: 0.00°
Count: 1
SteerAng n.Init
A4X4
Correct. I thought the instructions were in the ESP defeat thread...but I'm having trouble finding them.
08.5-11 ESP Defeat | VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com
I used to have the procedure in my messages before the forum switched over. I will continue to search, someone told me how to do it.
It's basically, use your original coding, adaption, drive the car, turn it off. Coding should stick.
Is this the procedure from APR? https://www.goapr.com/support/esp-defeat/
demon_GR
This sounds a bit familiar to me, and it happens to the R often. The culprit was the ABS wheel speed sensors. All the lights flashing that you describe are the same thing that happens.
Service center always said its because the vehicle is not driven enough. Im not saying that is exactly your issue, however it sounds very familiar to the issue that has been encountered before. So far ABS sensors have been changed about 3 or 4 times within the last 5 years.
Thankfully they are cheap otherwise I would be super annoyed with it. I brought it up before you go on and do more work than necessary just in case. Hope that helps.
GolfRfrontend
Before you post symptoms what was done to car. Don’t code any module because of fault. Coding is only required when module are replaced. #dontfrycontrolmodules
