New APR Ignition Coils are Here! Plug and Play, Multiple Colors, 10% More Spark Energy!
Arin@APR
GOLFMK7 Official Sponsor
Details Here
APR Ignition Coils are designed to be a direct plug-and-play upgrade to factory coils, and provide greater energy output, ensuring a stronger and more consistent spark. The commonplace replacement of factory ignition coils with those taken from the higher output Audi R8 is popularly believed to provide greater energy output. However, testing proves that they are no more powerful than the factory coils that are found on other engines. APR Ignition Coils increase energy output by up to 10% over stock. They are a direct upgrade or replacement, and come with a unique red, blue, or grey housing!
Features
  • Up to 10% more energy output than stock
  • Red housing with APR Logo
  • True upgrade, not just aesthetic
  • Direct plug-and-play
US Application Guide
PLEASE NOTE - If your factory ignition coils look physically different, other than color, these upgrades are not compatible.
2006-2013 Audi A3 2.0T (EA113, EA888.1)
2009-2013 Audi A3 Quattro 2.0T (EA888.1)
2005-2016 Audi A4 2.0T (EA888.2)
2006-2008 Audi A4 3.2L (EA837)
2005-2016 Audi A4 Quattro 2.0T (EA888.2)
2005-2009 Audi A4 Quattro 3.2L (EA837)
2010-2017 Audi A5 Quattro 2.0T (EA888.2)
2008-2010 Audi A5 Quattro 3.2L (EA837)
2012-2017 Audi A6 2.0T (EA888.2)
2006-2011 Audi A6 3.2L (EA837)
2013-2015 Audi A6 Quattro 2.0T (EA888.2)
2009-2018 Audi A6 Quattro 3.0T (EA837, EA837.EVO)
2005-2008 Audi A6 Quattro 3.2L (EA837)
2007-2008 Audi A6 Quattro 4.2L (EA824)
2012-2018 Audi A7 Quattro 3.0T (EA837, EA837.EVO)
2013-2018 Audi A8 Quattro 3.0T (EA837, EA837.EVO)
2007-2012 Audi A8 Quattro 4.2L (EA824)
2013-2016 Audi allroad 2.0T (EA888.2)
2015-2018 Audi Q3 2.0T (EA888.1)
2015-2018 Audi Q3 Quattro 2.0T (EA888.1)
2011-2017 Audi Q5 2.0T (EA888.1)
2013-2017 Audi Q5 3.0T (EA837)
2009-2012 Audi Q5 3.2L (EA837)
2011-2019 Audi Q7 3.0T (EA837, EA837.EVO)
2007-2010 Audi Q7 4.2L (EA824)
2008-2015 Audi R8 4.2L (EA824)
2009-2022 Audi R8 5.2L (EA824)
2007-2008 Audi RS4 4.2L (EA824)
2013-2015 Audi RS5 4.2L (EA824)
2010-2016 Audi S4 3.0L (EA837)
2010-2017 Audi S5 3.0T (EA837)
2008-2012 Audi S5 4.2L (EA824)
2007-2009 Audi S8 5.2L (EA824)
2014-2017 Audi SQ5 3.0T (EA837)
2008-2009 Audi TT 2.0T (EA113, EA888.1)
2009-2015 Audi TT Quattro 2.0T (EA888.2)
2012-2013 Audi TT RS Quattro 2.5T (EA855)
2009-2015 Audi TTS Quattro 2.0T (EA113)
2012-2021 Lamborghini Aventador 6.5L (L539)
2017-2017 Lamborghini Centenario 6.5L (L539)
2004-2009 Lamborghini Gallardo 5.0L (EA824)
2009-2014 Lamborghini Gallardo 5.2L (EA824)
2015-2021 Lamborghini Huracan 5.2L (EA824)
2011-2018 Porsche Cayenne 3.0T (EA837)
2012-2015 Porsche Panamera 3.0T (EA837)
2012-2012 Volkswagen Beetle 2.0T (EA888.1)
2006-2014 Volkswagen Beetle 2.5L (EA855)
2009-2017 Volkswagen CC 2.0T (EA888.1)
2007-2016 Volkswagen Eos 2.0T (EA113, EA888.1)
2010-2014 Volkswagen Golf 2.5L (EA855)
2012-2013 Volkswagen Golf R 2.0T (EA113)
2006-2014 Volkswagen GTI 2.0T (EA113, EA888.1)
2006-2013 Volkswagen Jetta 2.0T (EA113, EA888.1)
2005-2014 Volkswagen Jetta 2.5T (EA855)
2006-2010 Volkswagen Passat 2.0T (EA113, EA888.1)
2012-2014 Volkswagen Passat 2.5L (EA855)
2006-2009 Volkswagen Rabbit 2.5L (EA855)
2009-2017 Volkswagen Tiguan 2.0T (EA888.1)
2017-2018 Volkswagen Tiguan Limited 2.0T (EA888.1)
2011-2015 Volkswagen Touareg 3.0T (EA837)
2007-2008 Volkswagen Touareg 4.2L (EA824)
Do you have Ignition Coils for newer Cars, like 2015+ 1.8T/2.0T EA888 Gen 3, New V6 2.9T/2.0T, and New 4.0T?
YES Get them here
tdream1
Placed my order this morning. :)
9ermike
2013 GTI ... currently running stock coils and plugs. If I up grade to these coils should I change plugs as well? If so what do you recommend?
ROH ECHT
K04 PLAY
NGK BKR8EIX
9ermike....I believe the NGK OE plug is PFR7S8EG. It is a resisted plug of 1k Ohm. But the OE coil is low resistance of I believe 3.3 M Ohm. Lower resistance has higher current but lower voltage (as explained to me be NGK). The R8 coil is 5.31 M Ohm resistance and has lower current but higher voltage. I wish I could get someone like Arin, who is with a company showing graphs and making statements to give us numbers relatable to what we often see for coil voltage. What I mean is we can easily find statements saying coil-on-plug coils these days are 30k, 40k, or 50k volts. That is all I ever see. As in seeing the graph, in this case, of APR showing us output energy in mJ/ms. And I ask; what is this in voltage output? 30k, 40k, 50k, or 60k??? I just don't yet know. NGK has worked with me to understand some. I gave them the known results of the OE's 3.3 M Ohm and R8's 5.31 M Ohm resistance. One NGK tech says our recommended OE plug being 1k Ohm would be low resistance for a higher resistance and higher voltage coil-on-plug like that of the R8 coil. They recommend going to the 5k Ohm resistance plug options if coil resistance and voltage is increased. So yeah, NGK's BKR7EIX should work or BKR8EIX (cooler) if '7' is not cooling efficiently. Those plugs are Iridium__50k miles__0.031" gap__and are a 5k ohm plug. There is one Platinum(90k miles) 5k Ohm option by NGK; the PFR7B, it has a reduced gap of 0.027", and it works well with OE coils. There is one more option in a 5k Ohm NGK plug with a 0.031" gap, and it is somewhat new. It is FR7BHX-S Ruthenium....it's new so they list it currently to be good for 60k to 120k miles.
So Arin, and I am just only trying to understand...if in the graph I read the three tested, not including APR, all showing to be most near 53mJ/2ms....how is the APR result of nearest to 56mJ/2ms a 10% increase in energy output? Rhetorical of course. I suppose, I mean, I do see it happens earlier on the graph...the moment when the APR reaches 5mJ/0.4ms....this is the moment the others appear to be 0.5mJ lower (10% lower). The others appear to be 4.3 to 4.5mj/0.4ms. This is all fine and understandable...but does APR know what the voltage output is, relatable to as I said, for both the OE stock coil and for their MS100208 shown above? In that the values of OE stock and APR coils are 30k, 40k, 50k volts, or what? I can do more research to find simply enough how to convert volts from say 55mJ/2ms...but if you could save me the math!, I would appreciate it. LOL It's been a while since the math I've done and becoming stacks of paper could be measured in height by feet and inches.
ROH ECHT
K04 PLAY
Arin, if you want to skip all that above...what is the voltage output of both the OE stock and the APR MS100208 coils...as we are typically presented? Is it 30k, 40k, 50k volts?
torga
You can't compare point vs. point on this graph to get energy output, because the energy is being output over the entire pulse width. So to get the difference in output, you need to consider the area under the entire curve, over the full 2.0ms pulse width. Not just a single point. The total energy output over 2.0ms is what's ~10% higher than stock. Not just the 55mJ vs 53mJ at the very end of the curve.
ROH ECHT
K04 PLAY
Thank you...for that explanation. I can understand the area under the curve.
I truly don't care much about the accuracy of their 10% statement nor is the statement in question...and why I wrote "Rhetorical of Course." I am mostly only trying to find out if APR knows the voltage output of both the OE stock and theirs shown above, as it is commonly relayed to us. Which is typically; 30k to 50k volts. My interest is mostly based on always finding those numbers for volts when I find anything posted on the voltage output of newer coil-on-plug coils. But never seeing it being related to our stock and aftermarket coils. I would prefer to know what the voltage output is for both stock coil and their offering...if it is known. After writing all of that in the first post, and thinking I should just get to the point, is why I followed it with the shorter second post. I should just delete the first one really.
torga
To get from energy to voltage, we need current... which APR does not list on their website for this coil. So we're stuck.
Energy(E) = Power(P) X Time(t)
Power(P) = Voltage(V) X Current(I)
V = E/(I*t)
Arin@APR
I don't believe I have that specific information. In general I want to do a deeper dive into ignition coils with our engineers. I can't say how soon that will be, but we'll probably do a good writeup and video to jump more into this subject. I think it would be pretty interesting, and obviously would help move a few more units, so I'm down to do it!
ROH ECHT
K04 PLAY
Great, will be looking forward to more then.
ROH ECHT
K04 PLAY
V = E/(I*t)
Right, if we only knew the voltage or current, but we need one or the other. Hopefully APR will have more known values to share.
