NSTYGTI Build
MQB_7.5R
2011 Mk6 GTI
Carbon Steel Metallic LA9W
(Anything underlined is awaiting install)
Braking:
MK6 Golf R Front Calipers
MK6 Golf R Front Splash Shield
Tyrolsport Caliper Stiffening Kit
Hawk Talon 345mm Drilled + Slotted Front Rotors
Hawk HPS 5.0 Front Pads
ShopDAP Stainess Steel Lines Front + Rear
Pentosin Super DOT 4 Brake Fluid
R1 Concepts Geomet Drilled + Slotted Rear Rotors
Hawk HPS 5.0 Rear Pads
ECS Tuning Master Cylinder Brace
Drivetrain:
BFI Stage 1 Engine Mount
BFI Stage 1 Transmission Mount
Powerflex Track Dogbone Insert
Dieselgeek Sigma Six Short Throw Shifter Kit
Dieselgeek SuperPin and First Gear Getter
Dieselgeek Shifter Shaft Bushings0
034 Motorsport Shifter Bracket Bushings
Konig Hypergram 18x8.5 +43 Wheels and Nitto NT555 Gen 2 225/40/18 Tires
ECS Conical Lug Bolts 14x1.5 (30mm)
EMD Auto Hub Centric Rings
ECS Tuning Stage 2 Clutch with Single Mass Flywheel
ECS Tuning Clutch Bleeder Block
KMD Tuning Stainless Steel Clutch Line
Redline MT-90 Transmission Fluid
APR Spherical Pendulum Mount
Engine Bay:
Audi R8 Oil Cap
Porsche 991 Coolant Cap
Forge Motorsport Washer Bottle Filler
PTP Turbo Firewall Blanket
Gruven Parts Billet Dipstick Handle
Rennline Aluminum Belly Pan
ECS Tuning Skid Plate Reinforcement Kit
CTEK Trickle Charger Quick Connect
Engine Miscellaneous:
APR Coil Packs (Blue)
NGK IX Iridium Spark Plugs
CTS Turbo Catch Can Kit
iABED Industries Billet Rear Main Seal
Redline Synthetic 5W-40 Oil
APR Carbonio Intake
APR Carbon Fiber Turbo Inlet Pipe
Mabotech Street Bi-cooler
Innovate Motorsport Oil Pressure Gauge
USRT Oil Pressure Switch Adapter
New South Performance Boost Gauge
Wortec Aluminum Baffled Oil Pan
Lager Aluminum Upper Timing Cover
Elring Lower Timing Cover with OEM Main Seal
Revised OEM Timing Tensioner + Chain
Revised OEM Intake Manifold
Pierburg Vacuum Pump + OEM Gasket Replacement
Cam Girdle Reseal
OEM Camshaft Position Sensor Replacement
OEM Variable Timing Solenoid Replacement
OEM Oil Pressure Switch Replacement
OEM Serpentine Belt Replacement
Engine Software:
Stratified Automotive ProTune 93 Octane
VCDS Micro-Can
Engine Turbo:
CTS Turbo K04-X Turbo Kit
Neuspeed K04 Turbo Outlet Pipe with Welded Intercooler Adapter
Neuspeed Throttle Pipe
Turbosmart EM Plumb Back VR1 Diverter Valve
Bosch 4 Bar Map Sensor
Beluga Racing Catless Turboback Exhaust
Exterior:
Strafe Designs Rear Diffuser
Seibon OE Style Hood
Golf R Front Bumper
9006 to H11 Resistors for DRLs
G2 Lime Green Brake Calipers
COBB Rear Wiper Delete
Vega Modified V1 Spoiler Extension
Carbon Fiber Headlight Covers
ABT Style Front Grill
Genuine Euro Golf R Headlights
Genuine Euro Golf R Tail Lights
Interior:
BFI Leather Shift Knob
BFI Leather Shift Boot
EuroCubby and Gauge Trim
Euro Kreations Rear Seat Delete
Reupholstered Headliner with Factory Material
COBB Weathertech Floormats
Mk6 Golf R Black Steering Wheel Trim
Suspension:
Koni Yellow Sport Struts
Neuspeed Sport Lowering Springs
Neuspeed 25mm Rear Sway Bar
SuperPro 24mm Front Sway Bar
KMD Tuning Lower Front Stress Bar
KMD Tuning Upper Rear Stress Bar
Eurosport Rear X-Brace
Eurosport Upper Front Stress Bar
ECS Front Subframe Collar Kit
ECS Rear Subframe Collar Kit
SuperPro Front Sway Bar End Links
SuperPro Rear Sway Bar End Links
MQB_7.5R
Status as of 3/7/2022 :
Rear seats have been removed
Euro Kreations Rear Seat Delete is awaiting install.
Interior is stripped apart awaiting my reupholstered headliner.
MQB_7.5R
Status as of 3/14/2022
Got the new headliner reupholstered at Ronnie Price Upholstery and Top Shop in Fairfield, Ohio. Looks just like OEM!
Installed Euro Kreations Rear seat delete as well to shed some weight in the rear.
Decided it was time to get new headlights since my current Xenon's have tiny micro-scratches on the inside of the lenses. Ordered new Euro OEM Black Xenon Headlights from ShopDAP.
MQB_7.5R
Status as of 6/5/2022
ABT Style Front Grill Installed
Genuine Euro Golf R Headlights Installed
Genuine Euro Golf R Tail Lights Installed
P3 Analog Boost Gauge Installed
APR Pendulum Mount Installed
SuperPro 24mm Front Sway Bar installed
SuperPro Adjustable Front + Rear End Links Installed
