Official APR Golf R Products and Information
Arin@APR
GOLFMK7 Official Sponsor
Details Here
APR Ignition Coils are designed to be a direct plug-and-play upgrade to factory coils, and provide greater energy output, ensuring a stronger and more consistent spark. The commonplace replacement of factory ignition coils with those taken from the higher output Audi R8 is popularly believed to provide greater energy output. However, testing proves that they are no more powerful than the factory coils that are found on other engines. APR Ignition Coils increase energy output by up to 10% over stock. They are a direct upgrade or replacement, and come with a unique red, blue, or grey housing!
Features
  • Up to 10% more energy output than stock
  • Red housing with APR Logo
  • True upgrade, not just aesthetic
  • Direct plug-and-play
US Application Guide
PLEASE NOTE - If your factory ignition coils look physically different, other than color, these upgrades are not compatible.
2006-2013 Audi A3 2.0T (EA113, EA888.1)
2009-2013 Audi A3 Quattro 2.0T (EA888.1)
2005-2016 Audi A4 2.0T (EA888.2)
2006-2008 Audi A4 3.2L (EA837)
2005-2016 Audi A4 Quattro 2.0T (EA888.2)
2005-2009 Audi A4 Quattro 3.2L (EA837)
2010-2017 Audi A5 Quattro 2.0T (EA888.2)
2008-2010 Audi A5 Quattro 3.2L (EA837)
2012-2017 Audi A6 2.0T (EA888.2)
2006-2011 Audi A6 3.2L (EA837)
2013-2015 Audi A6 Quattro 2.0T (EA888.2)
2009-2018 Audi A6 Quattro 3.0T (EA837, EA837.EVO)
2005-2008 Audi A6 Quattro 3.2L (EA837)
2007-2008 Audi A6 Quattro 4.2L (EA824)
2012-2018 Audi A7 Quattro 3.0T (EA837, EA837.EVO)
2013-2018 Audi A8 Quattro 3.0T (EA837, EA837.EVO)
2007-2012 Audi A8 Quattro 4.2L (EA824)
2013-2016 Audi allroad 2.0T (EA888.2)
2015-2018 Audi Q3 2.0T (EA888.1)
2015-2018 Audi Q3 Quattro 2.0T (EA888.1)
2011-2017 Audi Q5 2.0T (EA888.1)
2013-2017 Audi Q5 3.0T (EA837)
2009-2012 Audi Q5 3.2L (EA837)
2011-2019 Audi Q7 3.0T (EA837, EA837.EVO)
2007-2010 Audi Q7 4.2L (EA824)
2008-2015 Audi R8 4.2L (EA824)
2009-2022 Audi R8 5.2L (EA824)
2007-2008 Audi RS4 4.2L (EA824)
2013-2015 Audi RS5 4.2L (EA824)
2010-2016 Audi S4 3.0L (EA837)
2010-2017 Audi S5 3.0T (EA837)
2008-2012 Audi S5 4.2L (EA824)
2007-2009 Audi S8 5.2L (EA824)
2014-2017 Audi SQ5 3.0T (EA837)
2008-2009 Audi TT 2.0T (EA113, EA888.1)
2009-2015 Audi TT Quattro 2.0T (EA888.2)
2012-2013 Audi TT RS Quattro 2.5T (EA855)
2009-2015 Audi TTS Quattro 2.0T (EA113)
2012-2021 Lamborghini Aventador 6.5L (L539)
2017-2017 Lamborghini Centenario 6.5L (L539)
2004-2009 Lamborghini Gallardo 5.0L (EA824)
2009-2014 Lamborghini Gallardo 5.2L (EA824)
2015-2021 Lamborghini Huracan 5.2L (EA824)
2011-2018 Porsche Cayenne 3.0T (EA837)
2012-2015 Porsche Panamera 3.0T (EA837)
2012-2012 Volkswagen Beetle 2.0T (EA888.1)
2006-2014 Volkswagen Beetle 2.5L (EA855)
2009-2017 Volkswagen CC 2.0T (EA888.1)
2007-2016 Volkswagen Eos 2.0T (EA113, EA888.1)
2010-2014 Volkswagen Golf 2.5L (EA855)
2012-2013 Volkswagen Golf R 2.0T (EA113)
2006-2014 Volkswagen GTI 2.0T (EA113, EA888.1)
2006-2013 Volkswagen Jetta 2.0T (EA113, EA888.1)
2005-2014 Volkswagen Jetta 2.5T (EA855)
2006-2010 Volkswagen Passat 2.0T (EA113, EA888.1)
2012-2014 Volkswagen Passat 2.5L (EA855)
2006-2009 Volkswagen Rabbit 2.5L (EA855)
2009-2017 Volkswagen Tiguan 2.0T (EA888.1)
2017-2018 Volkswagen Tiguan Limited 2.0T (EA888.1)
2011-2015 Volkswagen Touareg 3.0T (EA837)
2007-2008 Volkswagen Touareg 4.2L (EA824)
Do you have Ignition Coils for newer Cars, like 2015+ 1.8T/2.0T EA888 Gen 3, New V6 2.9T/2.0T, and New 4.0T?
YES Get them here
Thumper
FINALLY!!!!
YES, TAKE MY MONEY!!!!!!!!!!!!!!!!!!!!
Thank you Arin for once again making me sleep on the couch, but totally worth it.
Arin@APR
Arin@APR
APR Iridium Pro Spark Plugs are Here!
APR Iridium Pro Spark Plugs are the excellent upgrade for tuned engines. Our spark plugs are made from Iridium, which is one of the strongest materials you can use in this type of application. They run cooler, resist preignition, last longer than other materials with higher melting points, and even require less voltage to produce a strong spark. The electrode is harder and stronger than other materials, can dissipate heat more easily, is better protected from melting, cracking, and other limitations found with standard plugs. These plugs were designed for use on tuned and higher output vehicles that benefit from a plug cooler than the factory heat range. They are great for high boost, high cylinder pressure, high cylinder temperatures, and high power situations, and they pair nicely with a set of APR ignition coils, where applicable.
Features and Specs
  • Iridium alloy electrode tip
  • Heat range 9 spark plug (Similar: Bosch 3, Brisk 10, Denso 27, and NGK 9)
  • 152% higher melting point than silver, 125% higher than copper, and 38% higher than platinum.
  • Stronger than copper and platinum
  • Designed for high performance / tuned vehicle applications
  • Non-projected insulator design (Z1003100)
  • Projected insulator design (Z1003101)
  • Lower required supplied voltage
  • Cooler operating temperature than stock plugs
  • Optimized electrode design for hard to ignite fuels, such as ethanol
  • Resists preignition better than stock plugs
  • Perfect for upgraded APR vehicles
  • An excellent match for APR ignition coils
  • Thread reach: 26.5mm (Z1003100)
  • Thread reach: 26.5mm (Z1003101)
  • Thread diameter: 14mm
  • Hexagon: 16mm
  • Seat Type: Gasket
  • Install Torque: 25 Nm
  • Made in the EU
Product Pages:
EA888.3 / EA824 / EA855.1 / EA855.2 / EA824
Z1003100 - 26.5mm x 14mm x 16mm - HR 9
EA113 / EA888.1 / EA888.2 / EA837
Z1003101 - 19.0mm x 14mm x 16mm - HR 9
Check product page application guides and notes before ordering. Always check gap and sizes before installing.
Arin@APR
Product Page
Product Page
Product Page
The APR Throttle Booster instantly transforms the way your vehicle feels by customizing how quicky your throttle or accelerator pedal works. Simply plug it in and either use the wireless controller or smart phone app to set or customize how the pedal feels. Most people don't like the way their throttle pedal feels, and while tuning can help eliminate lag, everyone has a different opinion about how it should feel. This device lets you set it exactly the way you want and allows you to quickly switch between profiles. Set it to stock, sport modes, extreme modes, and eco modes with ease. Best of all, it's a quick plug and play device that can be removed at any time.
Features:
  • Improves throttle response and transforms the feel of the vehicle
  • Multiple switchable profiles including various sport modes, eco modes, and custom maps
  • Custom throttle mapping allows you to perfectly tune your throttle pedal
  • Thin and classy wireless controller
  • Bluetooth iOS and Android mobile app
  • No clunky boxes, wires, or controllers like other devices
  • Quick and easy plug-and-play design that is removable without a trace
  • Works on gas, diesel, alternative fuel, and electric vehicles
  • 30-day money back guarantee
[video]
iOS App
Android App
PCU (Pedal Control Unit)
Wireless Controller
App
Product Page
Product Page
Product Page
APR Throttle Booster with Wireless Controller and iOS/Android App!
Arin@APR
APR High-Flow Direct-Replacement Intake Filters are Here!
Product Page
APR High Flow Intake Filters are a direct upgrade to your factory intake system! Typically your engine is equipped with a cheap, mass-produced and restrictive paper filter system that must be replaced several times in the life of the vehicle. The APR Filter uses a proprietary, high-flow, cotton-gauze filtration material that is washable and will likely outlive the vehicle itself! The filtration material was flow-bench optimized to provide maximum performance while also providing excellent filtration that will keep your engine running clean for hundreds of thousands of miles with normal maintenance. With multiple decades of creating and selling high-flow filters for hundreds of thousands of vehicles with our upgraded intake systems, we're confident our line of drop-in filters will be an excellent upgrade for our budget-minded consumers!
In many cases, upgrading the intake system to an APR intake system is the best route to take for maximum performance, but that's not always possible for all vehicles and every budget. That's where our direct replacement filters shine. This is the easiest upgrade you can make to your factory intake system to maximize performance. The filter flows more than stock and has less pressure drop at the same flow rate, which means the engine doesn't need to work as hard to make the same, or more power.
Our drop-in filters are made for all engine types including gas, diesel, ethanol, or other fuels, and naturally aspirated, turbocharged, supercharged, and other hybrid configurations! In every scenario, our filter maximizes performance of the factory intake system. Expect sharper throttle response, a little more sound, and on turbocharged engines, less strain on the turbo with a reduction in turbo lag.
Features and Benefits
  • Maximizes engine performance
  • Flows more than stock
  • Lower pressure drop than stock at every flow rate
  • Sharpens response (Turbo/Throttle)
  • High-flow, proprietary cotton-gauze material
  • Washable and reusable for the life of the engine
  • Slightly enhances engine sound
  • Flow-bench optimized design
  • Works at any stage of performance
  • Compatible with the factory intake system
  • Decades of success designing high-flow filters for high performance applications
  • Does not negatively impact emissions
Get the details here and filter by your year make and model
Please note, the application guide is based on US models only, but these filters fit a vast amount of vehicles in the ROW. If you are outside the USA, choose a model close and cross reference the OEM filters listed on the product page to ensure it fit!
