maxtdi
Figured it would be nice to gather some info to point folks to.
What is known:
1. Unpredictable failure mileage could be as early as 10k and latest one so far happened at 60k.
2. Full engine replacement is recommended because jumped timing ruins both the head/valves and the bottom end.
3. VW seems to be picking up the tab while car is under the 5 yr 60k powertrain warranty.
4. Happens to tuned and untuned cars.
5. 2008-13 all Years seem to be affected
6. It seems that after 9/12 motor build dates updated tensioners were used
7. There is a TSB currently out on the issue:
Some Ideas for a fix
1.
Updated tensioner as such: Long term durability is still not proven.
http://www.golfmk6.com/forums/showthread.php?t=47082
2. OEM updated tensioner on the LEFT... the retainer on the factory installed tensioner fails... causing the chain to skip timing.
What is known:
1.
