Pcv question
FriggenT1
Banned
I decided to check a few things under the hood tonight, I noticed that when pulling the oil cap off, there's no resistance and air is actually blowing out, the engine also runs rough. I thought it was supposed to be difficult to pull the oil cap when at idle?
Dans GTI
It's supposed to be difficult to pull the cap off if there is a vac leak.
Define difficult, because normally there is some resistance when pulling the cap off normally.
FriggenT1
Banned
I always had a fairly strong vacuum when pulling mine off, there's basically none as I pull it away now and air just pours out (of course as there's a vacuum leak)
damagi123
i feel for you trying to chase this Friggen leak down man
urbanevil
PCV is an easy swap, might be worth it to swap, though I hate just throwing $ at parts without confirmation.
Sent from my SM-N910V using Tapatalk
Mk6 Steve
Hence why I bought a 034 catch can with africa plate...1 less point of failure
Calkulin
What PCV valve revision do you have? The E revision my car came with from the factory had a slight vacuum & oil leak, so I picked up an AC revision for less than $80 even though now, AH is the latest offered by VW
FriggenT1
Banned
What PCV valve revision do you have? The E revision my car came with from the factory had a slight vacuum & oil leak, so I picked up an AC revision for less than $80 even though now, AE is the latest offered by VW
I got the latest about 15-20k miles ago...AC iirc
damagi123
funny as i just came from the thread with the guy from new zealand who had to replace his k04 on his R BECAUSE of the africa plate
That wasn't meant to antagonize. It's just funny when something supposed to be a solution
BudgetPhoenix
Like it felt like the cap weighed 50lbs. Happened when my PCV diaphragm tore and it was sucking air through the pin hole. Its a mjaor difference as if I tried it ow
NNWGB6
I thought AE was for Audi models, and that requires seals rings and software updates.
Calkulin
You're right, AH is the latest for ours, that revision just stuck in my head for some reason :thumbsup:
