torga
I found this claim on Reddit and want to know if there's any truth to this at all. I've never heard of something like this.
"If you replace that (PCV) you need to replace the upper timing cover gasket as well as the turbo cut-off valve because the way those motors are designed if you replace one it will cause the others to go out shortly after (learned this from a close friend who is a Vw tech)"
