Kiev
First, I do not represent this company neither I am receiving any money or gifts from them
or from other company to write this review.
After I just got this electronic device 2 days ago I am doing this review
for all the people that does not like how the throttle response
was design on this vehicle, like me, and they have been trying to find a solution for this problem.
The PedalBox, if you do not know, is an electronic device that intercepts the signal
coming from your pedal accelerator and increases it by certain percentage considering the
program selected. You can google it if you want to know more about it.
This electronic device has 3 main programs: ECO, SPORT and SPORT+ with 6 different variations each one,
3 steps to increase and 3 steps to decrease the main response curve of each program which
gives you a really fine tuning of how you want the pedal throttle responds. Also, you
have the option to just turn it off and the signal is going to be back to stock.
Some points to consider:
1. It is expensive? YES
1. Does increase the engine power? NO
2. Does increase the engine response? YES
3. Does take out completely the existent lag? If you have a really sensitive foot and you are
VERY picky still there is a little bit, otherwise this is completely solved.
4. Can I change programs on the fly? YES
5. What I expect by using it? Expect the same feel as before and after you chipped your car.
For the people that has the APR switching option it is kind like switching between chipped
program(s) and the stock option. Pratically a new car.
6. Is It the same as If I press more the gas pedal? ABSOLUTELY NO.
Because you can switch program on the "fly" you can instantly notice how the car reacts
to each program and I am pretty sure, if you use it, you will not go back to the stock mode
anymore like me.
Even I read before a lot of controversy and negative arguments about using this electronic
device in other forums I decided to give it a try and I am very happy I did it.
I think this device really fixes in a big proportion the throttle response/lag on this car.
anymore like me.
