its aliveee!!!
Sorry to revive this thread but, now mine is making this popping noise when I turn too! and it does get worse with time, any ideas?
You have to adjust your endlinks people. I only had this problem once. Got some st coil overs and sure enough there it was. That same noise. Lol. if you drop your car or modify suspention in any way then you must also upgrade endlinks
In order to keep sway bar in the right geometry. White line adjustable end links are pricey but totally worth it. Ride to hard on the stock end links and they will pop! The longer or shorter you make the endlinks depends on your ride hight
