Questions about an android aftermarket head unit
Cdub3031988
hi, brand new here so I hope I'm in the right place. I just purchased a bineze android 10.1 inch head unit and I bought a scosche adapter to connect to the factory wire harness. I got it all wired up and the thing won't turn off when i turn the vehicle off. I can't seem to figure out what to do to fix this issue. I've seen online something about a can bus i believe but I feel mentally exhausted at this point to where I'm not sure what that is any more ha ha. I also see that there isn't a dimmer wire on the factory harness, I've seen some post where they splice the dimmer light switch wire or even the fuse box. I hope someone has figured this out because I can't seem to find enough info on this particular car to help me out. Thanks in advanced, I hope lol
Wiring harness: https://www.amazon.com/dp/B01NCJ2UE2/ref=cm_sw_r_other_apa_i_LogZEb7N1XFKH
Head unit: https://www.amazon.com/dp/B07WV34MFR/ref=cm_sw_r_other_apa_i_oqgZEbY5N3S2A
gijoewoz
Sounds like you swapped the switched, and constant power wires. Double check that you don't have the red and yellow wires swapped.
mkv_martinez
Did you ever get this figured out? I assume GIJoe's reply above was right.
Trigger wire must have been set somewhere that wasn't a switched power source.
Did it come with a wiring diagram? If you have a multi-meter its usually not too hard to track down a switched 12v source.
zrickety
The Fixer
The last android unit I bought came with a harness, but there was a red wire with a disconnect I had to unplug for it to turn off. Took me a minute to figure it out.
