They aren't hard to replace and a shop shouldn't charge you too much. Any car with 120k miles is gonna be coming up on needing new mounts and suspension components. These engine mounts especially are quite soft from the factory. They pretty much turn to jelly
Do you have an intake? If so, first check where it passes over the master cylinder sometimes it can touch the brake lines and cause vibration felt through the pedals and you may need to adjust it. Pretty common problem
