Torqueflite
Hey guys. I have a '13 Golf that I've changed all four wheel bearings on, but it keeps eating right rear bearings. After replacing a second one under parts warranty and it also failing in short order, I inspected closer and found the spindle is bent causing the premature bearing failures. I have the 30mm diameter spindles/bearings. My dealership wants over $500 for a new spindle/knuckle assembly. Rock Auto only wants about $50, but they only list the 32mm size.
Does anyone know if the two sizes of knuckle/spindles can be interchanged and are identical (other than the spindle diameter of course)? If yes, I'll buy the knuckle and 32mm bearing from Rock Auto and live with my rear knuckles having different sized bearing diameters, knowing that I saved $400 on the part. But I don't want to proceed with ordering if they're not identical. Thanks in advance for any knowledge.
Chad
'13 Golf
Chad
'13 Golf
