Rebuild finished. Extra parts leftover?
DougD
I've just about finished reinstalling the engine in my 2011 GTI but have two things I can't figure out.....
The first is this connection/plug. Its the only one left and I don't see ANY other sensors, etc. that aren't connected. Yellow and brown wires (2) with a two pin connector.
the last is this plastic/rubber disc that ended up on the garage floor under the car???? Any ideas where it goes?
BudgetPhoenix
A Water pump temp sensor connector? I believe CBFA engines have two on the water pump.
AntiGTI
I don't know what it is so I'm following along, but the rubber disk recently ended up on the floor of my garage. I did notice that it fits perfectly into one of the accessory pullies, but looking up the parts I don't see any dust boots. Please update if you figure it out.
DougD
I think you're correct. I noticed the same disc on the front of the AC compressor in other pix.....
And I think BudgetPhoenix is correct about the temp sensor. I swapped that connector out....and now have this one with no home......
Its located on the same harness as the Altenator and AC compressor wires.....but i don't see any open connection points?!?...... the 2 wires appear to be Orange and Red/violet..... any help is greatly appreciated.
AntiGTI
Confirmed. The rubber piece goes on the AC pulley. Checked while working on my wife's Tiguan today.
