A few posts down someone asked about a good shop for a turbocharger replacement. I don't want to sound like a broken record and I don't have anything to gain by recommending these guys, but AST (Auto Select Tuning) in Brampton can do this job with their eyes closed..
They specialize in VW and Audi and know their stuff. They can do it all when it comes to VW's and they also fabricate so if something isn't right they will make it right..
They stand behind their work.. It's so hard to find honest mechanics that know their stuff. These guys are reliable and that goes a long way with me..
Tell them Richard with the sleeper Golf R and MK1 Audi TT sent you, maybe you get a touch better deal!
Thanks, I went to AST, got the updated tensioner. You were right The guys at AST are very friendly. I paid $500 all together. My old Tensioner was still in good shape, but it was really bugging me as theres no way of knowing when the oil pressure will drop and screw up the tensioner. But now I have piece of mind and dont have to worry as much.
Thanks Again
Looking to get this done on my '12 with 141K km on it. Were your guides and chain in fine condition, and the cover re-installed as opposed to replaced at that price?
I'd appreciate it if you would please let me know more details about the parts and labour here. Thanks.
Also what kind of turn around time is involved?
Hey Sorry for the late reply,
$500 only covered the cost of tensioner and labour, its about a 3-4hour job. Labour is $100/h. Hence the cost. My timing chain had no damage, so I opted not to go for a full timing chain replacement, just the tensioner. I believe they replaced the cover (Not 100% sure I have to check my receipt), they did replace the seals. Also you can give them a call, they are very friendly, and they will give you a quote.
Good info!
Are you having problems or are you doing this as preventative maintenance?
I'm wondering if this is something I should do on my 2011.
This is not a "should do" but a MUST Do.Good info!
Good info!
mileage?
Had mine done at K&H on St Clair by Mario. straight up guy. $1100. tensioner/guides/ new style chain.. was over 250K.. had the upgraded tensioner put in when i was at 120ish K i think
The Timing Chain Tensioner failed or Tiguan at 122k km with regular oil changes and dealer serviced.
Thanks.
No problems. Just fear.
Edit: If this known faulty or "very prone to failure" part (upper timing chain tensioner) is a known ticking time-bomb, sales script such as this are very effective at getting me to open the wallet:
"Keeping tension on your timing chain is imperative for keeping your cams turning properly. If some slop develops in your chain because of a poor tensioner, the timing set can skip a tooth, causing catastrophic damage and potentially ruining your engine. This replacement can keep everything tight.
The chain runs against this tensioner which keeps your chains tight on the cam gears and crank. It makes sure no teeth are missed and your engine stays in time. Quiets loud chains."
Just trying to pin down which GTA shop to use.
So I just check my receipt for the work done. They did not replace the lower timing cover.
OEM Updated Timing Chain Tensioner - $87.88
Timing Cover Sealant - $25
Crank Bolt- $13
Labour -$315
Total: $440.88
with Tax: $498.19
Hope this helps in choosing which place to go to.
Regards,
Sorry I didn't see your question. Yes we used the Electronic one. I'm not familiar with autos too much but thought it wise to use the Electronic brake instead of resting the weight of the Tiguan on the auto tranny. I changed the rear brake pads before, retacting the brake pistons using VAGCOM or OBD11 is the only real difference.forwardlean said:Did you use your e-brake on that thing? Was it the electronic one?....
Auto Select Repair in Newmarket, :thumbsup: Yup I know Franz well, he is a fantastic mechanic, very well known in Porsche circles, stand up guy.Well, got her done this past week, at just shy of 143K km. Went to a place very local, less than 7 km from home - a bit closer (~10x) than to Brampton. I wanted to get a now and future go-to VW specialist that was convenient and these guys - Auto Select Repair on Gorham Street in Newmarket came highly recommended by a long time co-worker Porsche guy (and senior structural engineer) who had been making the long trek from Pickering to see these Newmarket guys for more than a decade. VW, Audi & Porsche specialists with glowing reviews as far as I could find....
