So I replaced my PCV with a new one. I didn't have any codes but I've been dealing with oil leaks, the main one remaining now is the rear main. Swapped the PCV and now the engine acts weird when coming off the throttle. I have a manual so imagine driving along, coming to a stop pop it to neutral and then at that point the revs drop to where they should be, around 800 and start to climb. Sometimes they will start to climb to 1600 or so and as soon as I come to a full stop they drop to like 1200, hang there for a sec and drop to 800. The car thrown a CEL so I will scan it but anyone have any ideas just based on that?
OP, I started experiencing nearly the same exact issue several weeks ago and I've been chasing the root cause ever since. My car started idling a little bit rougher and would experience odd RPM's fluctuations like yours. My car would drive normally, feel as though it had the same power, and was getting the same MPG as always, but when I would come to a stop at a red light or stop sign my RPM's would jump by +600 to +1000 for several seconds before dropping back down to normal.
Since then I replaced the PCV with the latest revision of a genuine VW PCV, and on the first attempt I saw no improvement at all. I was led to believe that I was unlucky enough to have received a faulty PCV, so I exchanged my PCV for another one. At this point I saw a slight improvement for close to a week in how my RPM's behaved when coming to a stop, but then they went right back to a +600 to +1000 increase every time I would stop.
Next I replaced my MAF, which has made a large improvement but has still not quite fixed the RPM's issue. Now when I come to a stop my RPM's either remain the same or increase by +200 to +400.
I just did a smoke test and found no leaks, as well as performed a thorough visual check of all vacuum hoses.
At this point I'm looking to acquire a scanner so I can clear the CEL and see if the CEL comes back on or not. If it comes back, it seems logic points me to the upstream o2 sensor next.
