TakmaN
I'm undertaking installing an OEM badge reverse camera and want to make sure I do it safely. For the constant 12v power needed, I'm using a fuse connector to the fuse box but have no idea what size fuse(s) I'll need. It has two spaces for fuses and one video tutorial said to use 2x10A but ECS tuning shows tapping (without using a fuse connector) into the hot 12v wiring with only a 5A fuse. Anyone have input as to what the proper fuse size is? And should I be using the same fuse size in both slots on the fuse connector?
