mrnetzley21
Anyone else get a weird shaking at idle? its not the fans cause there not on. its a 2012 vw mk6
If there is no code and you are not misfiring then you might have a busted motor mount.I have the Same problem, no mods, 37000 miles. Dealer did not want to look at it, because it did not throw a code.
When you guys say shake do you mean a slight vibration. Very minimal vibration or lots of vibration. Small engines use balance shafts that reduce vibration, but it can't get rid of all vibration so there will be some vibration and that is normal.
Mine does this as well.
Slight shudder at idle every few seconds, very intermittent, and no perceptible change registered by the tachometer and no CEL. It almost feels like a misfire, and happens regardless of fuel. I've only got 5800 miles on mine.
