I have a Dieselgeek shifter installed. Also metal bracket/ bushings.
I have a lot of slop side to side, even when in gear. No front to back looseness. Pulled the console, the cable end bushings look fine, so does the first gear getter. Everything seems to move in a 1:1 ratio.
Replaced the plastic shifter ball housing and shimmed it as described by Dieselgeek. No difference. There’s slight play on the bushings on the shifter shaft itself, but it’s not the cause of the looseness.
Any ideas?
Any ideas?
