SoWalGTI's stock+ build
SoWalGTI
Previous GTI build below.
New Chapter Begins - Sportwagen Build
Guess who's back...back again!
2011 Mk6 JSW SE2.5
Current Mods
Engine:
  • IE Performance Intake Manifold
  • IE Stage 2 + SRI Tune
  • IE air intake
  • IE billet valve cover
  • IE fuel rail
  • IE Vacuum Pump Delete
Gearbox:
  • Integrated Engineering TCU tune
Exterior:
  • OEM LED Bi-Xenon headlight retrofit
  • OEM R-Line foglight retrofit
  • OEM Votex front spoiler
  • OEM Golf R side skirts
  • OEM Votex rear spoiler and diffuser
  • OEM Votex hatch extension
  • OEM GTI front grille
  • Anti-glare, aspherical blind spot mirrors
Interior:
  • RNS-315 head unit retrofit
  • VW aluminum glovebox handle
Suspension/Chassis:
  • Koni Struts
  • H&R Sport Springs
  • Audi TT strut mounts/bearings
Wheels/Tires/Brakes:
  • OEM VW Durban 18" wheels
  • Firestone Indy500 225/40/18
  • OEM Golf R brake retrofit
  • Hawk Talon Performance rotors
  • Carbotech Pads
  • StopTech stainless lines
  • Motul Fluid
Sportwagen build starts here
GTI build begins below
GTI SOLD 9/23/2017
2012 Candy White GTI, Manual
Engine:
  • Unitronic K04
  • Unitronic Stage2+
  • Neuspeed FMIC
  • CTS Turbo TOP
  • CTS Turbo Throttle Pipe
  • SPM catted down pipe
  • ECS baffled catch can
  • ECS carbon-fiber Luft-Technik Intake
  • ECS carbon fiber engine cover
  • Porsche oil/coolant caps & black washer fluid cap
  • RevD Diverter Valve
  • R8 Coil Packs / NGK Iridium Plugs BKR7EIX
  • 034 Motorsport mounts
Transmission:
  • Southbend Stage2 Daily
  • 034 Motorsport billet aluminum dogbone mount
  • Audi S3 Euro short-shifter
  • 034 Motorsport aluminum shifter bracket bushings
Exterior:
  • OEM Xenon headlight retrofit
  • OEM LED tail lights
  • OEM Golf R Side skirts
  • Höen fog lights
  • Klii Motorwerks rear badge inlay (Interlagos pattern)
  • Klii motorwerks license plate frame (Interlagos pattern)
  • Anti-glare blind spot side mirrors
  • OEM color-matched front lip
  • Shaved front bumper
  • Piano black painted bumper inserts and grille
Interior:
  • Golf R leather interior swap
  • European cup holder
  • P3Cars vent gauge in red/white
  • Klii Motorwerks steering wheel badge inlay (Interlagos pattern)
  • OEM Monster Mats
  • Upgraded to RNS-315
  • OEM rear window shades
  • Hatch pop kit with button
Suspension/Chassis:
  • H&R SuperSports
  • Koni STR.T coils/shocks
  • Tyrolsport stage2 hatch bracing
  • Unibrace UB
  • Neuspeed RSE12 rims, 18x8 gunmetall
  • Michelin Pilot Super Sports 225/40/18
  • Golf R Front brakes
  • StopTech Stainless Lines
  • CarboTech pads
SoWalGTI
Parts have arrived!
H&R Super Sports, Koni STR.T struts/shocks, Audi TT bearings/bushings, all new hardware, stretch bolts and mounts.
Neuspeed RSE12's in Gunmetal.
After the installation by Volkswagen.
SoWalGTI
LED Tails installed along with the KliiMotorwerks license plate frame and badge inlay.
KliiMotorwerks steering-wheel badge inlay.
SoWalGTI
How's the ride quality of that combo an now much u pay for it together ?
The ride quality is awesome. Significant reduce in body roll, does great over city roads and is only slightly more stiff than stock. Overall a little more sporty feel, but nothing drastic.
SoWalGTI
P3Cars digital vent gauge installed. I chose the red/white lighting which turned out to be a perfect match with the gauge clusters. The fit and finish are pretty impressive. The gauge was a PITA to installed into the vent however. I'd recommend spending the extra coin and getting the entire assembly if I had to do it over.
I will take some day time pics and update the thread soon.
I also used my Micro-Can for the first time today to clear the bulb out error from my LED taillights install. For anyone trying to find out what to code byte 18 for to get rid of the errors, I used 1F and tested extensively. Works perfectly.
North American region, halogen headlights, led tails w/o fog = 1F (stock was 03)
CarniifeX
Very nice! Gosh I have a weak spot for Neuspeed wheels.
Love the P3 gauge, it's really a useful tool.
SoWalGTI
Thanks man! All of the Neuspeed wheels just look like they were made for these cars. They almost seem as if they would be OEM on a higher trim level package.
I plan on using the P3Gauge to track power increases, temprature differences, etc with each mod. I know it wont be 100% accurate all the time, but it will be nice to use it to document baseline numbers and then track any improvements with each mod.
CarniifeX
I completely agree about Neuspeed. They have some of the best fitting, looking and performing parts on the market.
I usually keep my gauge on intake temps, sometimes I'll check coolant on long drives. It's really a great 'gauge'. It's really accurate, straight from the ECU though I would recommend getting the analog boost sensor.
