Spacers on stock detroits?
GTi-GUY86
Just curious if anyone has put spacers on the stock detroits. If so what size are you using?
Im running spacers on the rear. Currently running 13mm out back on stock suspension. I have a set of FK Streetlines :w00t: just need some time to install them. Nice amount of poke for a 13. :cool:
Gti For Me
Fronts use 10mm hubcentric spacer and get 37mm lug bolts
Rears use 15mm hubcentric spacer and get 45mm lug bolts
You will be flush to the fender if you are lower on suspension
My fronts and rears are 1.2" lower on neuspeed springs and i donot rub one bit
Top gear
I'm just stock height and not planning on lower any time soon so what sizes spacers should I get
i'm thinking 6mm in the front and 8mm in the back.
