mono98
Ricardo
Hello GOLFMK6 Forums!
I know this topic has been big on the forums, but I cant find an answer
I been searching this topic to find the answer for almost a month, but every time somebody open this topic the answer from other members are LINKS which head me to the same old ones that I can't find the answers. Please I need Personalize help if possible
Thanks!!!!!
My 2013 GTI 2dr manual trans, is the Base Model, came with No Sunroof, no NAV no Steering wheels controls no nothing... (RNS-510 Installed already :w00t
So I order The face plate, Module and harness to make my steering wheel with controls.
This is what I Bought:
Face Plate (Controls Buttons) - 5K0998537B
Module - 5K0959542C
Harness - 5K0971584C
This Should be plug and play with coding, I'm a newbie and not an expert. especially with VAG-COM which I have but I don't know how to use it well.
I removed the face plate and airbag, change the harness on the airbag plug it to the module and the face plate to the module.
Now I don't have Horn and the controls does not light up, do nothing. I figure is matter of coding.
I follow this instructions which are the only ones I could find:
then start VCDS and put this code in module 16 (steering wheel) 108A140000
it does work for gti / gtd with manual gearbox and cruise control. Zero errors in ecu
You have to disable the MFD commands via wiper lever to avoid conflicts with the new buttons and to enable the new parts.
If you do not change the levers and stay with 5K0 953 513 S (MFD control wiper lever) you will get a "bad coding warning" but everything is fine. If you want to eliminate this warning you have to swap also the 5K0 953 513 S (MFD control wiper lever) with the version without the MFD buttons on wiper lever (5K0-953-513-M-9B9).
Now.. When I change the code from 5080140000 to 108A140000 and press "DO IT" I have this error:
Also tried to check the multifunction steering wheel box on the 5080140000 code, just to see, and same code as with the 108A140000
Now this is a DEAD END for me
This is the scan I did.
VCDS Version: Release 12.12.0
Data version: 20130910
Chassis Type: AJ (7N0)
Scan: 01 03 08 09 15 16 17 19 1C 25 2E 37 42 44 46 52 56 77
VIN: WVWEV7AJ4DW123021
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1C-Position Sensing -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AS HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0020
Revision: AAH18--- Serial number:
Coding: 0403010A18070160
Shop #: WSC 01357 011 00200
VCID: 77FD0D5E066D49A6A59-8022
No fault code found.
Readiness: 1110 0101
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Component: ESP MK60EC1 H31 0152
Revision: 00H31001
Coding: 114B600C492400FD880B06E6921A0041B70800
VCID: 7DF11F76E45163F6FF5-8028
Address 08: Auto HVAC (J301) Labels: 7N0-907-426.clb
Part No SW: 7N0 907 426 BH HW: 7N0 907 426 BH
Component: AC Manuell H20 0505
Revision: 00001018
Coding: 0010002002
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_SE36.rod
VCID: 7BF5116EF2456DC6C11-802E
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 086 T HW: 1K0 937 086 T
Component: BCM PQ35 M 111 0709
Revision: AC111709
Coding: 6F180A3A98252A04008800C1710003E44E610386534D8D60648020200040
VCID: 4189A386D829C716DBD-8014
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 03011 26 0512
Coding: 009795
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 M HW: 5C0 959 655 M
Component: AirbagVW10G 014 0726
Serial number: 003L4R017K63
Coding: 00004737
ASAM Dataset: EV_AirbaVW10SMEVW360 001026
ROD: EV_AirbaVW10SMEVW360_VW01.rod
VCID: 3C77D272B7CBAAFE88B-8069
Seat occupied recognition:
Subsystem 1 - Part No SW: 5K0 959 339 B HW: 5K0 959 339 B
Component: BF-Gewichtss. 006 0001
Serial number: ---0000R--000050BH00
Crash sensor for side airbag; driver side:
Subsystem 2 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H02 ----
Serial number: 3572MSME33132275ZZZJ
Crash sensor for side airbag; passenger side:
Subsystem 3 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Beif.V H02 ----
Serial number: 3582MSME75027170ZZZN
Crash sensor for side airbag; rear driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3512QSME643A223CZZZX
Crash sensor for side airbag; rear passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3522QSME7419235DZZZ-
Crash sensor for front airbag; driver side:
Component: F.Sens.Fahr --- ----
Serial number: 35527SME39446C2EZZZU
Crash sensor for front airbag; passenger side:
Component: F.Sens.Beif --- ----
Serial number: 35627SME43426C2EZZZO
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 BA HW: 5K0 953 549 C
Component: Lenks.Modul 008 0090
Revision: -------- Serial number: 90422LLJ0010P
Coding: 5080140000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS.rod
VCID: 70EF3642AB031E9E643-8025
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5K6 920 973 C HW: 5K6 920 973 C
Component: KOMBI H05 0705
Serial number: 00000000000000
Coding: 270D01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04716
ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
VCID: 377DCD5E8EED89A6659-8062
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AF HW: 7N0 907 530 AF
Component: J533 Gateway H52 1634
Revision: H52 Serial number: 060113F1001287
Coding: 350000
VCID: 74E73A52D71B22BE80B-8021
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 5N0 919 879 HW: 5N0 919 879
Component: Kompass 002 0002
Revision: 00002000 Serial number: 1225223RM3S907
Coding: 0000002
VCID: FEF3987AA957F8EE66F-80AB
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 0705
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03709
ROD: EV_Immo_UDS_VDD_RM09_VN35.rod
VCID: EADBA42A0DDF644EAA7-80BF
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 F HW: 5N0 035 342 F
Component: SG EXT.PLAYER H19 0550
Revision: A1001003 Serial number: 7664075489
Coding: 010100
VCID: 2A5BE42A455F244EEA7-807F
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3C0 035 684 C HW: 3C0 035 684
Component: RNS-MID H17 1140
Revision: AB001001 Serial number: VWZ6Z7H9245037
Coding: 040100020100008100
Shop #: WSC 05314 123 12345
VCID: 2345090E2275F506A91-8076
1 Fault Found:
01523 - Microphone for Telephone (R38)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 73
Mileage: 0 km
Time Indication: 0
Date: 2016.14.24
Time: 18:25:37
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 5K0 959 701 B HW: 5K0 959 701 B
Component: Tuer-SG 009 2117
Coding: 0001076
VCID: 3169F346A88957962BD-8064
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 74 3305
Revision: 00H22000
VCID: 377DCD5E46ED89A6659-8062
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 5K0 959 702 B HW: 5K0 959 702 B
Coding: 0001076
VCID: 326BFC4AAD8F6C8E527-8067
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 73
Mileage: 0 km
Time Indication: 0
Date: 2016.14.24
Time: 18:25:37
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664075954
Coding: 0A10040000010100
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA.rod
VCID: 3A7BD46ABDFF94CE9A7-806F
End ---------------------------------------------------------------------
THANK YOU VERY MUCH FOR TAKING YOUR TIME AND HELP ME!!! :thumbup:
Thanks!!!!!
Module - 5K0959542C
Revision: 00H31001
Revision: 00001018
Coding: 0010002002
Revision: AC111709
Coding: 009795
Coding: 00004737
Coding: 5080140000
Coding: 270D01
Coding: 350000
Coding: 0000002
Coding: 000000
Coding: 010100
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 73
Mileage: 0 km
Time Indication: 0
Date: 2016.14.24
Time: 18:25:37
Coding: 0001076
Revision: 00H22000
Coding: 0001076
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 73
Mileage: 0 km
Time Indication: 0
Date: 2016.14.24
Time: 18:25:37
ROD: EV_UHVNA.rod
