I am some what experienced with stretched tires so I'll comment.
I wouldn't run that extreme stretch on 19"s. Heres my reason why.
To keep the overall diameter close to stock, you have to run a 35 series tire. The problem with that is, stretching a 215/35/19 onto a 9.5" wide wheel, leaves you very very little sidewall, Thus leaving very little between your wheel and pavement. Its a bent wheel waiting. That's very cool, if you are doing it for a show, or don't daily drive on those wheels etc. So my advice to you for stretching tires on 19's, is not to go too far. a 225/35/19 will be a much more daily usable and back friendly on that 9.5". I Probably would run a 215/35/19 on the front since its not too much of a stretch. Also, stay away from Toyo Proxy4's. Their sidewalls are really really soft. I, as well as other s I've talked to, have run into chewed up beads/inner sidewall once their toast and dismounted.
