Tyler12108
also check your F16 fuse in your engine bay
Does yours come on for a bit then turn off after a few seconds then give your the bulb errors on your dash.Ive got the same lights out and it's not the bulbs. Its in the wiring harness in the hatch. I've not had time to pull apart but I think the rear washer line is leaking causing a corrosion issue .
Will take a look at the fuse when i get home. But if the fuse is bad the lights should not come on at all right?also check your F16 fuse in your engine bay
Typically, yes.Will take a look at the fuse when i get home. But if the fuse is bad the lights should not come on at all right?
Yeah, gonna check that out this weekend. Is there some device i can use to detect a splice in the wire or would a multimeter work.I was gonna say this next but hoping it wasn't the case. I tried looking at wiring on my system but for whatever reason it didn't have the hatch lights.![]()
Yep. And sometimes one will work and then next time it won't. Which makes me suspect a harness issue. The computer will turn off the light if it detects high resistance to protect the circuit.Does yours come on for a bit then turn off after a few seconds then give your the bulb errors on your dash.
Yup same exact issue, gonna take a look at this weekend and hopefully nothing crazy.Yep. And sometimes one will work and then next time it won't. Which makes me suspect a harness issue. The computer will turn off the light if it detects high resistance to protect the circuit.
Damn rolling computer we call a car yet love it!
I have had the same problem and fix it today as all bulbs and wiring were fine so tool the bulbs out of the boot and replaced them with t10 5w and it has fixed all the problems and its bright enoughhello, did you ever manage to resolve this problem?
I have the same exact issue on my 2013 gti
chee
Thanks for the info mate - I tried this today and the error is gone!I have had the same problem and fix it today as all bulbs and wiring were fine so tool the bulbs out of the boot and replaced them with t10 5w and it has fixed all the problems and its bright enough
