Teaser: 034Motorsport Adjustable Rear Upper Control Arms
Status
Not open for further replies.
034Motorsport
Here's a sneak peek at the upcoming 034Motorsport Adjustable Rear Upper Control Arms for the Volkswagen MkV/MkVI and Audi 8J/8P! :thumbup:​
These arms allow for a significant amount of camber adjustment on top of what the stock eccentric bolt provides. Whether you're setting your car up for stance or performance, these will allow you to get it dialed in faster and easier than ever before.
Official release and introductory special pricing coming soon! :)
034Motorsport
Retail and introductory special pricing information will be available with the the official product release next week. :)
In the meantime, here are a couple more pictures of the finished production parts:
chinqutie
subbed. :thumbsup:
TXBDan
Nice. Any plans to make a tubular front LCA with adjustable camber? THAT'd be sweet.
034Motorsport
Definitely look great, but those heim joints won't hold up well to a Chicago winter.
We will have rubber dust boots available as an option, and we've used these sphericals with dust boots successfully for many years in harsh environments and climates. :thumbsup:
Confused with the terminology here, this is the "control blade" trailing arm?
No, it's the rear upper control arm, or number 13 in the ETKA diagram below.
The rear trailing arm is number 2 in the same diagram.
We do offer an upgrade to spherical bearings from the stock rubber rear trailing arm bushings, which is probably one of the best bang-for-the-buck suspension/handling modifications after a rear sway bar:
Rear Trailing Arm Spherical Bearing Upgrade Kit, Volkswagen MkV/MkVI and Audi 8J/8P
Uamishka
034motorsport keeps on delivering! I can't wait for more info and the pricing. Keep it coming guys;-)
GP813
in for more info!
034Motorsport
The full spherical arms are now released, and available at an introductory price of $355.50 per set for the first 10 buyers!
Retail: $395.00
Introductory Special: $355.50
Control Arm Pair, Motorsport, Rear Upper Adjustable, 8J/8P Audi & MkV/MkVI Volkswagen
We're proud to offer 034Motorsport Rear Adjustable Upper Control Arms for MkV/MkVI Volkswagen and 8J/8P Audi applications!
These arms are manufactured from billet aluminum and feature genuine Aurora spherical bearings. They are a direct replacement for the stock stamped steel and rubber arms, and allow for approximately 5 degrees of camber adjustment, on top of what the stock eccentric bolt allows.
Features:
  • Billet Aluminum Construction - Anodized Black
  • Genuine Aurora Spherical Bearings
  • Approximately 5 Degrees of Camber Adjustment (-2.4 Degrees or +2.6 Degrees)
  • Adjustable in 1/36" Increments. Each 1/36" Corresponds to ~0.18 Degrees.
Fitment:
  • 2005 - 2013 Audi A3/S3/RS3 (8P) - All Models
  • 2007 - 2013 Audi TT/TTS/TTRS (8J) - All Models
  • 2007 - 2009 Volkswagen Eos (MkV) - All Models
  • 2010 - 2013 Volkswagen Eos (MkVI) - All Models
  • 2006 - 2009 Volkswagen Golf/Jetta/GTI/GLI/Rabbit/R32 (MkV) - All Models
  • 2010 - 2013 Volkswagen Golf/Jetta/GTI/GLI/Rabbit/R (MkVI) - Independent Rear Suspenion (IRS) Models Only
  • 2006 - 2013 Volkswagen Passat - All Models
  • 2008 - 2013 Volkwagen Tiguan - All Models
Replaces:
  • 1K0505323N
These arms are perfect for track junkies and the hellaflush crowd alike!
If you're a track junkie, these arms will allow you to dial in your camber as desired for track events, and eliminate the stock rubber bushings, which deflect under load.
If you're hellaflush, these arms will make you more flush, by allowing you to run hella negative camber.
Please Note: Do not run these arms with less than 8 threads engaged in the aluminum body!
Click Here To Order!
Status
