goddamnit. I've been rubbing with my 235's for a while now and I'm just a smidge lower than DG's.
So I've been looking into getting the RSe05s (17x8.0) at 235/45 on DGs. Some folks say I'll rub, others say I won't. Really want to go as fat as I can just so I can make those potholes a bit smoother but without having to roll. Would love your opinion!
And yours too mycrors07 if you're available!
What's your wheel specs? Rubbing front or back?
you'll be fine
It's a case by case thing with those specs (depending on the offset of course), but you generally should be alright if the offset is ~40-45+
I'm on karthoums with 10mm spacers in the front and rubbing up there a bit. (w/ 235s)
Looking at SSR GT3 wheels, 18x8.5 et 37. I know I need wobble bolts, the bore is 72. Since its 37et, will I need spacers? Will I also need tires?
5x112
Guys out there running 10 et35 in the rear what are you running camber wise? Need a number give my alignment guy
